- Oct 21, 2002
- Houghton, Michigan
Whats better to have in a system, a reservoir or a t fitting setup? Please explain the "function" differences of each
frostmeister said:although there are more joins and points where it could leak as well.
frostmeister said:What I was saying is that a reservoir would get rid of bubbles better than a T piece - not that a T piece would cause bad temps, or that a reservoir would cause bubbles. I was assuming that the flow of water past a T piece would drag bubbles with the flow more than a reservoir where bubbles have a time to rise to the top and collect there. It's not like a T piece wouldn't perform the same job over time.
masitti said:Wow... that's really odd that it takes so long to bubble out. Mine was done after about 20 minutes.
who/where selling a small res.??mfpmax said:mostly cause the res will just basically be a small tank in front of the pump, like the ones they sell for the Ehiem pumps.
tseongsun said:I have a DangerDen one, I don't recommend it though. The intake is way too high and causes a jacuzzi effect and actually creates bubbles. The only way to get mine to work is to fill it to overflowing and then screw the cap down and even then it has trouble.
I'm thinking of either trying to find someone who has some spongy eheim filter left over or just goin to a T.
