Resolution issue on 6870
DjWolf37
VA
I currently have a XFX HD-687X-CNFC card and the highest resolution option it shows is 1920x1080. according to the specs the max should be 2560 x 1600. Why are the higher options not displaying, am I missing something?
Its because you (likely) do not have a monitor that supports that resolution.
Well this sucks since there is a 1 or 2 inch border around my 42" led tv....and i didnt realize my tv is laking on features like zoom untill after i purchased it.
1080 or 720 monitor?
Regardless, I believe there is a function in your CCC called overscan. that should fix it.
