- Nov 12, 2004
- suburbs of chicago
Does anyone know if the CMX512-3200C2PRO (xms pc3200 with LEDs) is the same exact memory/chips as just regular xms pc3200? If not, does anyone know what kinds of chips the PRO version uses?
Diablo23RD said:Suma, check these link, All dead. Thanks!
SteveOCZ said:PC 3700 gold rev3 and pc4000 gold rev 2 are both Hynix DT-D5
Not sure what else is missing but some of the platinum ram that doesnt have TCCD is infineon C die (aka CH-5) and we use hynix of some sort in the faster speed perfomance level stuff (ct or bt-d5 AFAIK). If you have other specific ones you need info on I can look because I don't really have all the info here.
You can be almost guaranteed that they use CH-5.WinWiz said:I would really like to know what chips are on these KHX3500A/512 but i dont wanna woid my warrenty by removing the heatspreader...
Don't worry about having a warrantee left, bro. I don't think I've had one for months.WinWiz said:The modded BIOS work fine, just hoping my mobo doesnt die while using it, my hardware dealer once told me "flashing bios woids warrenty"...
