I'm taking another crack at OCing my system to see what I can get out of it. I've read a few differnt FAQ's on the A64 3200+ Winchester and i've see 2.8 - 2.9 Ghz for these cores. I want to see if my system can even get to 2.5 or 2.7 Ghz if possible. The following images show my CPU, mobo, and RAM. I have the Zalman CNPS7700 mounted on my Winny. Also my MSI board supplies a piece of software called Core Center where you can monitor CPU temps, fan speeds, voltages and CPU speed with FSB frequency and mulitplier ratio. You can also adjust FSB freq., but the software adjusts FSB and fan speed based on core temp. The following image show the specs of my rig.
(note: this image was taken when I was testing a lower multiplier and higher FSB)
I basically want to get all I can out of my rig, but I'm really new to this. I got so far as to set in BIOS the overclocking feature to run a stable machine at +3% FSB (206 Mhz x 10.0 = 2060 Mhz). I have ran that setting for several months with no problems. I would also assume that my RAM modules were running at 206 Mhz each.
The next tweak I have done is to open Core Center and changed the FSB up to 212 Mhz. With the computer idaling Core Center reported overall speeds of 2120 Mhz and CPU-Z confirmed it. When I ran the CPU under stress (either using BIONIC or super pi) core center or cpu-z reported the CPU ramping down to 2060 Mhz and my CPU temp would approach 57c. The typical idal temp for my CPU is about 45c - 48c.
I honestly don't know if I have wonderful cooling for my CPU, however my machine is very quiet. I am really mystified on how to manipulate my RAM settings to keept the frequency about 215 Mhz (which I think is stable for my RAM). I also have no clue about the RAM timings or what to set mine at for the type of chips I have. All I can say on my RAM chips is that they aren't anything special. No heat spreaders no particular brand name. I basically bought middle of the road chips so i could run Dual Channel on this machine.
I could really use a hand in tweaking my settings and if anyone else out there has had success with the same CPU and heatsink/fan please let me know what you were able to achieve.
Thanks in advance for anyone who replies.
