Rheobus and the Antec SX1040
cyber mouse45
Cyber Cheesiest Senior
SC
To all of you wondering if the front door on the Antec sx1040 will close with a Rheobus installed, the answer is no. To make it close, you need to trim the knobs down to 0.468 or less. I just thought I’d let everyone know.
BTW, when you’re done grinding them down, don’t pick them up right away like I did. There’re very very HOT. :p
vtec96
FL
Hey thanks for the advise... I was about to get a bus for the same case...BTW, would that be the case for pretty much any bus, I would think they are similar in size/specs?
cyber mouse45
cyber mouse45
SC
I'm not sure. The problem was the far left and far right knobs. The door just curves in too much, and they hit it. But if you have a drill and a grinder or a Dremel, you can mod them so they work. that's what I did. :)
DKC
are u talking abotu the Rheobus 17w Fan Station
And does this basically apply for alll Antec's with the door on the front?
cyber mouse45
cyber mouse45
SC
That would be the one. I got mine from pcmods.
I'm not a 100% sure about all the Antec cases with doors, but I would guess so.
