- Feb 3, 2002
- Lexington, Virginia
i am gonna get 2 Comair Rotron Major's (or the circular ones)...
obviously i'm concerned about the noise at some times, so i was wondering if anyone made rheostats or fanbuses that can handle that kind of power
what would be ideal would be if i could plug the fans into a bus and with the flip of a switch just activate the bus, instead of lowering the voltage/wattage/whatever it is...
i know that there are rheostats that could handle this, but they're apparently expensive...is there any way to wire a fanbus to simply activate it, thus lowering the power to the fans, instead of already having the Rotrons at a lowered power?
For those who don't know, they operate @ 25W and run @ 2.26 Amps...personally, i dont know what the hell this means, but i do know that alot of power is required to run these...
They will be the only two fans in my case (one in front bottom for intake and one in top for exhaust), and I want to be able to slow them down if i want to d/l something overnight or whatever
-peter
-peter
