Mobile20 said:
So I should have no problem running 2 Panaflo (4w each) fans off of a 12.5w, 35ohm rheostat?
You should have no trouble running 8W of power through the rheostat. I'd just double-check to see whether or not a heatsink is recommended for that particular rheostat. (Many fanbuses based on rheostats have heatsinks on the rheostats.) Personally, I use a different configuration which doesn't require heatsinks (and I only use 1/4 W rheostats), so I can't really advise further there.
And I think that the value of the resistor (35 Ohms) is enough. One fan running at full speed uses .333 A. So, you can estimate an "internal resistance" (this is very crude, but okay) of 36 Ohms. (12 / .333 ). So, if you turn the rheostat up all the way on one fan, you'll roughly be running 6V across the fan. (Careful -- it may stop turning at that speed.) With two fans in parallel, the "internal resistance" is 1/(1 / 36 + 1/36) + 1 / ( 2/36) = 36/2 = 18 Ohms. So, cranking up to the full 35 Ohms gives a little under 8V drop across the rheostat and 4V drop across the fans. It'll definitely be enough to slow them (to a halt, in this case).
These are guesstimates, and you should certainly experiment with them when you get them before you solder them all together.
I hope this helps -- Paul
