Right PPD?
DarkWhite
Great North
Since I'm new to folding and I'm not sure of the standards I was wondering what kind of PPD I should be getting with my setup, and if there's anyway to optimise it.
First of all, I'm getting about 4200 PPD folding on my P2 965 and an HD 4850.
Second is my current setup, and feel free to laugh, but don't reply unless you intend to help.
I started folding using the Standard F@H for my CPU only.
I then added my GPU, using one of the clients available off the F@H site.
I then read the guide about installation, and proceeded to add NotFred's on 2 VM's, each using 2 cores, as that's what the guide said.
My current output (via FahMon) is
CPU-120 PPD
GPU-950 PPD
VM1-1435 PPD
VM2-1685 PPD
I am willing to change things around, as long as it's cleary explained, and I can keep my existing OS.
If you are running VM's you can do away with the windows client, which I am guessing you have labeled as CPU. It should free up the CPU a little bit so that the VM's can produce more PPD. I don't really know ATI's numbers, but I am sure someone will be along shortly to chime in.
If you are using 2 cores per NotFred's VM, then you may want to stop the single cpu client, as it is probably a) killing your GFX card output, and b) slowing your VMs down.
did that, waiting For FahMon to realize that one client has dissappeared :p
EDIT: Roughly the same PPD as before, 4210, VM's at 1720,1430
Okay, now HFM has alerted me to the fact that my names were not all the same (DOH!)
So I go to change them in the VM's and they change, and then switch back (DOH!)
It's reporting that they're folding, for T32, but it's not under my username.
Okay that's sorted, but now one's runnning in standard, and one's running SMP's, and the settings are Exactly the same.
Where are you looking to see if the settings are exactly the same?
Because 99.9% of the time, that's not the case. :)
one place to check right off, is the FAHlog.txt file, right at the time that you started or re-started, the last WU.
That first 50 lines or so of output has a lot of information. If you'll paste it into this thread, I'll be glad to look it over - for both folding clients.
Next, is the client.cfg file for both clients. Paste it up as well, if you would.
The number of the client, should be different for each one, of course (1-16 iirc), with gpu's getting #3 by default.
Usually, it's a typo of some sort - like SMP instead of smp (yes, they are case sensitive) or -smp (which is correct), is typed in as - smp (one extra space). Things like that.
The way I have it set up was through the NotFred client for virtual machines, I don't really type anything anywhere.
I'm looking at the webpage for remote setup, (192.168.0.*) and all are exactly the same.
The commands that HFM.net is sowing are -local, and -forceasm on both.
One has -smp2 (possibly with a space). The other does not.
-smp2 is running async
not -smp2 is running noframetimes
-smp2 is just under 2k PPD
not -smp2 is at about 400 PPD
SMP2:
Log
--- Opening Log file [December 16 23:48:05]
# SMP Client ##################################################################
Folding@Home Client Version 6.02
http://folding.stanford.edu
Launch directory: /etc/folding/1
Executable: ./fah6
Arguments: -local -forceasm -smp 2
Warning:
By using the -forceasm flag, you are overriding
safeguards in the program. If you did not intend to
do this, please restart the program without -forceasm.
If work units are not completing fully (and particularly
if your machine is overclocked), then please discontinue
use of the flag.
[23:48:05] - Ask before connecting: No
[23:48:05] - User name: DarkWhite (Team 32)
[23:48:05] - User ID: F65133A42E07E7A
[23:48:05] - Machine ID: 1
[23:48:05]
[23:48:05] Loaded queue successfully.
[23:48:05]
[23:48:05] + Processing work unit
[23:48:05] At least 4 processors must be requested.Core required: FahCore_a2.exe
[23:48:05] Core not found.
[23:48:05] - Core is not present or corrupted.
[23:48:05] - Attempting to download new core...
[23:48:05] + Downloading new core: FahCore_a2.exe
[23:48:06] + 10240 bytes downloaded
[23:48:06] + 20480 bytes downloaded
[23:48:06] + 30720 bytes downloaded
[23:48:06] + 40960 bytes downloaded
[23:48:06] + 51200 bytes downloaded
[23:48:06] + 61440 bytes downloaded
[23:48:06] + 71680 bytes downloaded
[23:48:06] + 81920 bytes downloaded
[23:48:06] + 92160 bytes downloaded
[23:48:06] + 102400 bytes downloaded
[23:48:06] + 112640 bytes downloaded
[23:48:06] + 122880 bytes downloaded
[23:48:06] + 133120 bytes downloaded
[23:48:06] + 143360 bytes downloaded
[23:48:06] + 153600 bytes downloaded
[23:48:06] + 163840 bytes downloaded
[23:48:06] + 174080 bytes downloaded
[23:48:06] + 184320 bytes downloaded
[23:48:06] + 194560 bytes downloaded
[23:48:06] + 204800 bytes downloaded
[23:48:06] + 215040 bytes downloaded
[23:48:06] + 225280 bytes downloaded
[23:48:06] + 235520 bytes downloaded
[23:48:06] + 245760 bytes downloaded
[23:48:06] + 256000 bytes downloaded
[23:48:06] + 266240 bytes downloaded
[23:48:06] + 276480 bytes downloaded
[23:48:06] + 286720 bytes downloaded
[23:48:06] + 296960 bytes downloaded
[23:48:06] + 307200 bytes downloaded
[23:48:06] + 317440 bytes downloaded
[23:48:06] + 327680 bytes downloaded
[23:48:06] + 337920 bytes downloaded
[23:48:06] + 348160 bytes downloaded
[23:48:06] + 358400 bytes downloaded
[23:48:06] + 368640 bytes downloaded
[23:48:06] + 378880 bytes downloaded
[23:48:06] + 389120 bytes downloaded
[23:48:06] + 399360 bytes downloaded
[23:48:06] + 409600 bytes downloaded
[23:48:06] + 419840 bytes downloaded
[23:48:06] + 430080 bytes downloaded
[23:48:06] + 440320 bytes downloaded
[23:48:06] + 450560 bytes downloaded
[23:48:06] + 460800 bytes downloaded
[23:48:06] + 471040 bytes downloaded
[23:48:07] + 481280 bytes downloaded
[23:48:07] + 491520 bytes downloaded
[23:48:07] + 501760 bytes downloaded
[23:48:07] + 512000 bytes downloaded
[23:48:07] + 522240 bytes downloaded
[23:48:07] + 532480 bytes downloaded
[23:48:07] + 542720 bytes downloaded
[23:48:07] + 552960 bytes downloaded
[23:48:07] + 563200 bytes downloaded
[23:48:07] + 573440 bytes downloaded
[23:48:07] + 583680 bytes downloaded
[23:48:07] + 593920 bytes downloaded
[23:48:07] + 604160 bytes downloaded
[23:48:07] + 614400 bytes downloaded
[23:48:07] + 624640 bytes downloaded
[23:48:07] + 634880 bytes downloaded
[23:48:07] + 645120 bytes downloaded
[23:48:07] + 655360 bytes downloaded
[23:48:07] + 665600 bytes downloaded
[23:48:07] + 675840 bytes downloaded
[23:48:07] + 686080 bytes downloaded
[23:48:07] + 696320 bytes downloaded
[23:48:07] + 706560 bytes downloaded
[23:48:07] + 716800 bytes downloaded
[23:48:07] + 727040 bytes downloaded
[23:48:07] + 737280 bytes downloaded
[23:48:07] + 747520 bytes downloaded
[23:48:07] + 757760 bytes downloaded
[23:48:07] + 768000 bytes downloaded
[23:48:07] + 778240 bytes downloaded
[23:48:07] + 788480 bytes downloaded
[23:48:07] + 798720 bytes downloaded
[23:48:07] + 808960 bytes downloaded
[23:48:07] + 819200 bytes downloaded
[23:48:07] + 829440 bytes downloaded
[23:48:07] + 839680 bytes downloaded
[23:48:07] + 849920 bytes downloaded
[23:48:07] + 860160 bytes downloaded
[23:48:07] + 870400 bytes downloaded
[23:48:07] + 880640 bytes downloaded
[23:48:07] + 890880 bytes downloaded
[23:48:07] + 901120 bytes downloaded
[23:48:07] + 911360 bytes downloaded
[23:48:07] + 921600 bytes downloaded
[23:48:07] + 931840 bytes downloaded
[23:48:07] + 942080 bytes downloaded
[23:48:07] + 952320 bytes downloaded
[23:48:07] + 962560 bytes downloaded
[23:48:07] + 972800 bytes downloaded
[23:48:07] + 983040 bytes downloaded
[23:48:07] + 993280 bytes downloaded
[23:48:07] + 1003520 bytes downloaded
[23:48:07] + 1013760 bytes downloaded
[23:48:07] + 1024000 bytes downloaded
[23:48:07] + 1034240 bytes downloaded
[23:48:07] + 1044480 bytes downloaded
[23:48:07] + 1054720 bytes downloaded
[23:48:07] + 1064960 bytes downloaded
[23:48:07] + 1075200 bytes downloaded
[23:48:07] + 1085440 bytes downloaded
[23:48:07] + 1095680 bytes downloaded
[23:48:07] + 1105920 bytes downloaded
[23:48:07] + 1116160 bytes downloaded
[23:48:07] + 1126400 bytes downloaded
[23:48:07] + 1136640 bytes downloaded
[23:48:07] + 1146880 bytes downloaded
[23:48:07] + 1157120 bytes downloaded
[23:48:07] + 1167360 bytes downloaded
[23:48:07] + 1177600 bytes downloaded
[23:48:07] + 1187840 bytes downloaded
[23:48:07] + 1198080 bytes downloaded
[23:48:07] + 1208320 bytes downloaded
[23:48:07] + 1218560 bytes downloaded
[23:48:07] + 1228800 bytes downloaded
[23:48:07] + 1239040 bytes downloaded
[23:48:07] + 1249280 bytes downloaded
[23:48:07] + 1259520 bytes downloaded
[23:48:07] + 1269760 bytes downloaded
[23:48:07] + 1280000 bytes downloaded
[23:48:07] + 1290240 bytes downloaded
[23:48:07] + 1300480 bytes downloaded
[23:48:07] + 1310720 bytes downloaded
[23:48:07] + 1320960 bytes downloaded
[23:48:07] + 1331200 bytes downloaded
[23:48:07] + 1341440 bytes downloaded
[23:48:07] + 1351680 bytes downloaded
[23:48:07] + 1361920 bytes downloaded
[23:48:07] + 1372160 bytes downloaded
[23:48:07] + 1382400 bytes downloaded
[23:48:07] + 1392640 bytes downloaded
[23:48:07] + 1402880 bytes downloaded
[23:48:07] + 1413120 bytes downloaded
[23:48:07] + 1423360 bytes downloaded
[23:48:07] + 1433600 bytes downloaded
[23:48:07] + 1443840 bytes downloaded
[23:48:07] + 1454080 bytes downloaded
[23:48:07] + 1464320 bytes downloaded
[23:48:07] + 1474560 bytes downloaded
[23:48:07] + 1484800 bytes downloaded
[23:48:07] + 1495040 bytes downloaded
[23:48:07] + 1505280 bytes downloaded
[23:48:07] + 1515520 bytes downloaded
[23:48:07] + 1525760 bytes downloaded
[23:48:07] + 1536000 bytes downloaded
[23:48:07] + 1546240 bytes downloaded
[23:48:07] + 1556480 bytes downloaded
[23:48:07] + 1566720 bytes downloaded
[23:48:07] + 1576960 bytes downloaded
[23:48:07] + 1587200 bytes downloaded
[23:48:07] + 1597440 bytes downloaded
[23:48:07] + 1607680 bytes downloaded
[23:48:07] + 1617920 bytes downloaded
[23:48:07] + 1628160 bytes downloaded
[23:48:08] + 1638400 bytes downloaded
[23:48:08] + 1648640 bytes downloaded
[23:48:08] + 1658880 bytes downloaded
[23:48:08] + 1669120 bytes downloaded
[23:48:08] + 1679360 bytes downloaded
[23:48:08] + 1689600 bytes downloaded
[23:48:08] + 1699840 bytes downloaded
[23:48:08] + 1710080 bytes downloaded
[23:48:08] + 1720320 bytes downloaded
[23:48:08] + 1730560 bytes downloaded
[23:48:08] + 1740800 bytes downloaded
[23:48:08] + 1751040 bytes downloaded
[23:48:08] + 1761280 bytes downloaded
[23:48:08] + 1771520 bytes downloaded
[23:48:08] + 1781760 bytes downloaded
[23:48:08] + 1792000 bytes downloaded
[23:48:08] + 1802240 bytes downloaded
[23:48:08] + 1812480 bytes downloaded
[23:48:08] + 1822720 bytes downloaded
[23:48:08] + 1832960 bytes downloaded
[23:48:08] + 1843200 bytes downloaded
[23:48:08] + 1853440 bytes downloaded
[23:48:08] + 1863680 bytes downloaded
[23:48:08] + 1873920 bytes downloaded
[23:48:08] + 1884160 bytes downloaded
[23:48:08] + 1894400 bytes downloaded
[23:48:08] + 1904640 bytes downloaded
[23:48:08] + 1914880 bytes downloaded
[23:48:08] + 1925120 bytes downloaded
[23:48:08] + 1935360 bytes downloaded
[23:48:08] + 1945600 bytes downloaded
[23:48:08] + 1955840 bytes downloaded
[23:48:08] + 1966080 bytes downloaded
[23:48:08] + 1976320 bytes downloaded
[23:48:08] + 1986560 bytes downloaded
[23:48:08] + 1996800 bytes downloaded
[23:48:08] + 2007040 bytes downloaded
[23:48:08] + 2017280 bytes downloaded
[23:48:08] + 2027520 bytes downloaded
[23:48:08] + 2037760 bytes downloaded
[23:48:08] + 2048000 bytes downloaded
[23:48:08] + 2058240 bytes downloaded
[23:48:08] + 2068480 bytes downloaded
[23:48:08] + 2078720 bytes downloaded
[23:48:08] + 2088960 bytes downloaded
[23:48:08] + 2099200 bytes downloaded
[23:48:08] + 2109440 bytes downloaded
[23:48:08] + 2119680 bytes downloaded
[23:48:08] + 2129920 bytes downloaded
[23:48:08] + 2140160 bytes downloaded
[23:48:08] + 2150400 bytes downloaded
[23:48:08] + 2160640 bytes downloaded
[23:48:08] + 2170880 bytes downloaded
[23:48:08] + 2181120 bytes downloaded
[23:48:08] + 2191360 bytes downloaded
[23:48:08] + 2201600 bytes downloaded
[23:48:08] + 2211840 bytes downloaded
[23:48:08] + 2222080 bytes downloaded
[23:48:08] + 2232320 bytes downloaded
[23:48:08] + 2242560 bytes downloaded
[23:48:08] + 2252800 bytes downloaded
[23:48:08] + 2263040 bytes downloaded
[23:48:08] + 2273280 bytes downloaded
[23:48:08] + 2283520 bytes downloaded
[23:48:08] + 2293760 bytes downloaded
[23:48:08] + 2304000 bytes downloaded
[23:48:08] + 2314240 bytes downloaded
[23:48:08] + 2324480 bytes downloaded
[23:48:08] + 2334720 bytes downloaded
[23:48:08] + 2344960 bytes downloaded
[23:48:08] + 2355200 bytes downloaded
[23:48:08] + 2365440 bytes downloaded
[23:48:08] + 2375680 bytes downloaded
[23:48:08] + 2385920 bytes downloaded
[23:48:08] + 2396160 bytes downloaded
[23:48:08] + 2406400 bytes downloaded
[23:48:08] + 2412195 bytes downloaded
[23:48:08] Verifying core Core_a2.fah...
[23:48:08] Signature is VALID
[23:48:08]
[23:48:08] Trying to unzip core FahCore_a2.exe
[23:48:09] Decompressed FahCore_a2.exe (5509624 bytes) successfully
[23:48:09] + Core successfully engaged
[23:48:14]
[23:48:14] + Processing work unit
[23:48:14] At least 4 processors must be requested.Core required: FahCore_a2.exe
[23:48:14] Core found.
[23:48:14] Working on Unit 03 [December 16 23:48:14]
[23:48:14] + Working ...
[23:48:14]
[23:48:14] *------------------------------*
[23:48:14] Folding@Home Gromacs SMP Core
[23:48:14] Version 2.10 (Sun Aug 30 03:43:28 CEST 2009)
[23:48:14]
[23:48:14] Preparing to commence simulation
[23:48:14] - Ensuring status. Please wait.
[23:48:23] - Assembly optimizations manually forced on.
[23:48:23] - Not checking prior termination.
[23:48:25] - Expanded 4845787 -> 23999905 (decompressed 495.2 percent)
[23:48:25] Called DecompressByteArray: compressed_data_size=4845787 data_size=23999905, decompressed_data_size=23999905 diff=0
[23:48:25] - Digital signature verified
[23:48:25]
[23:48:25] Project: 2675 (Run 1, Clone 294, Gen 194)
[23:48:25]
[23:48:25] Assembly optimizations on if available.
[23:48:25] Entering M.D.
[23:48:31] Using Gromacs checkpoints
[23:48:32] Multi-core optimizations on
[23:48:36] Resuming from checkpoint
[23:48:36] Verified work/wudata_03.log
[23:48:36] Verified work/wudata_03.trr
[23:48:36] Verified work/wudata_03.xtc
[23:48:36] Verified work/wudata_03.edr
[23:48:37] Completed 172980 out of 250000 steps (69%)
[00:01:01] Completed 175000 out of 250000 steps (70%)
[00:16:18] Completed 177500 out of 250000 steps (71%)
[00:31:00] Completed 180000 out of 250000 steps (72%)
[00:46:53] Completed 182500 out of 250000 steps (73%)
CFG
[settings]
username=DarkWhite
team=32
asknet=no
bigpackets=big
machineid=1
[http]
active=no
host=localhost
port=8080
[core]
checkpoint=15
[clienttype]
type=3
Not SMP2
Log
--- Opening Log file [December 17 00:46:04]
# Linux Console Edition #######################################################
Executable: ./fah6
Warning:
use of the flag.
[00:46:04] - Ask before connecting: No
[00:46:04] - User name: DarkWhite (Team 32)
[00:46:04] - User ID: 511859BE24CD3867
[00:46:04] - Machine ID: 1
[00:46:04]
[00:46:04] Loaded queue successfully.
[00:46:04]
[00:46:04] + Processing work unit
[00:46:04] Core required: FahCore_78.exe
[00:46:04] Core not found.
[00:46:04] - Core is not present or corrupted.
[00:46:04] - Attempting to download new core...
[00:46:04] + Downloading new core: FahCore_78.exe
[00:46:04] + 10240 bytes downloaded
[00:46:05] + 20480 bytes downloaded
[00:46:05] + 30720 bytes downloaded
[00:46:05] + 40960 bytes downloaded
[00:46:05] + 51200 bytes downloaded
[00:46:05] + 61440 bytes downloaded
[00:46:05] + 71680 bytes downloaded
[00:46:05] + 81920 bytes downloaded
[00:46:05] + 92160 bytes downloaded
[00:46:05] + 102400 bytes downloaded
[00:46:05] + 112640 bytes downloaded
[00:46:05] + 122880 bytes downloaded
[00:46:05] + 133120 bytes downloaded
[00:46:05] + 143360 bytes downloaded
[00:46:05] + 153600 bytes downloaded
[00:46:05] + 163840 bytes downloaded
[00:46:05] + 174080 bytes downloaded
[00:46:05] + 184320 bytes downloaded
[00:46:05] + 194560 bytes downloaded
[00:46:05] + 204800 bytes downloaded
[00:46:05] + 215040 bytes downloaded
[00:46:05] + 225280 bytes downloaded
[00:46:05] + 235520 bytes downloaded
[00:46:05] + 245760 bytes downloaded
[00:46:05] + 256000 bytes downloaded
[00:46:05] + 266240 bytes downloaded
[00:46:05] + 276480 bytes downloaded
[00:46:05] + 286720 bytes downloaded
[00:46:06] + 296960 bytes downloaded
[00:46:06] + 307200 bytes downloaded
[00:46:06] + 317440 bytes downloaded
[00:46:06] + 327680 bytes downloaded
[00:46:06] + 337920 bytes downloaded
[00:46:06] + 348160 bytes downloaded
[00:46:06] + 358400 bytes downloaded
[00:46:06] + 368640 bytes downloaded
[00:46:06] + 378880 bytes downloaded
[00:46:06] + 389120 bytes downloaded
[00:46:06] + 399360 bytes downloaded
[00:46:06] + 409600 bytes downloaded
[00:46:06] + 419840 bytes downloaded
[00:46:06] + 430080 bytes downloaded
[00:46:06] + 440320 bytes downloaded
[00:46:06] + 450560 bytes downloaded
[00:46:06] + 460800 bytes downloaded
[00:46:06] + 471040 bytes downloaded
[00:46:06] + 481280 bytes downloaded
[00:46:06] + 491520 bytes downloaded
[00:46:06] + 501760 bytes downloaded
[00:46:06] + 512000 bytes downloaded
[00:46:06] + 522240 bytes downloaded
[00:46:06] + 532480 bytes downloaded
[00:46:06] + 542720 bytes downloaded
[00:46:06] + 552960 bytes downloaded
[00:46:06] + 563200 bytes downloaded
[00:46:06] + 573440 bytes downloaded
[00:46:06] + 583680 bytes downloaded
[00:46:06] + 593920 bytes downloaded
[00:46:06] + 604160 bytes downloaded
[00:46:06] + 614400 bytes downloaded
[00:46:06] + 624640 bytes downloaded
[00:46:06] + 634880 bytes downloaded
[00:46:06] + 645120 bytes downloaded
[00:46:06] + 655360 bytes downloaded
[00:46:06] + 665600 bytes downloaded
[00:46:06] + 675840 bytes downloaded
[00:46:06] + 686080 bytes downloaded
[00:46:06] + 696320 bytes downloaded
[00:46:06] + 706560 bytes downloaded
[00:46:06] + 716800 bytes downloaded
[00:46:06] + 727040 bytes downloaded
[00:46:06] + 737280 bytes downloaded
[00:46:06] + 747520 bytes downloaded
[00:46:06] + 757760 bytes downloaded
[00:46:06] + 768000 bytes downloaded
[00:46:06] + 778240 bytes downloaded
[00:46:06] + 788480 bytes downloaded
[00:46:06] + 798720 bytes downloaded
[00:46:06] + 808960 bytes downloaded
[00:46:06] + 819200 bytes downloaded
[00:46:06] + 829440 bytes downloaded
[00:46:06] + 839680 bytes downloaded
[00:46:06] + 849920 bytes downloaded
[00:46:06] + 860160 bytes downloaded
[00:46:06] + 870400 bytes downloaded
[00:46:06] + 880640 bytes downloaded
[00:46:06] + 890880 bytes downloaded
[00:46:06] + 901120 bytes downloaded
[00:46:06] + 911360 bytes downloaded
[00:46:06] + 921600 bytes downloaded
[00:46:06] + 931840 bytes downloaded
[00:46:06] + 942080 bytes downloaded
[00:46:06] + 952320 bytes downloaded
[00:46:06] + 962560 bytes downloaded
[00:46:06] + 972800 bytes downloaded
[00:46:06] + 983040 bytes downloaded
[00:46:06] + 993280 bytes downloaded
[00:46:06] + 1003520 bytes downloaded
[00:46:06] + 1013760 bytes downloaded
[00:46:06] + 1024000 bytes downloaded
[00:46:06] + 1034240 bytes downloaded
[00:46:06] + 1044480 bytes downloaded
[00:46:06] + 1054720 bytes downloaded
[00:46:06] + 1064960 bytes downloaded
[00:46:06] + 1075200 bytes downloaded
[00:46:06] + 1085440 bytes downloaded
[00:46:06] + 1095680 bytes downloaded
[00:46:06] + 1105920 bytes downloaded
[00:46:06] + 1116160 bytes downloaded
[00:46:06] + 1126400 bytes downloaded
[00:46:06] + 1134407 bytes downloaded
[00:46:06] Verifying core Core_78.fah...
[00:46:06] Signature is VALID
[00:46:06]
[00:46:06] Trying to unzip core FahCore_78.exe
[00:46:07] Decompressed FahCore_78.exe (3435296 bytes) successfully
[00:46:07] + Core successfully engaged
[00:46:12]
[00:46:12] + Processing work unit
[00:46:12] Core required: FahCore_78.exe
[00:46:12] Core found.
[00:46:12] Working on Unit 05 [December 17 00:46:12]
[00:46:12] + Working ...
[00:46:12]
[00:46:12] *------------------------------*
[00:46:12] Folding@Home Gromacs Core
[00:46:12] Version 1.90 (March 8, 2006)
[00:46:12]
[00:46:12] Preparing to commence simulation
[00:46:12] - Ensuring status. Please wait.
[00:46:29] - Assembly optimizations manually forced on.
[00:46:29] - Not checking prior termination.
[00:46:29] - Expanded 464078 -> 2244013 (decompressed 483.5 percent)
[00:46:29]
[00:46:29] Project: 6316 (Run 257, Clone 2, Gen 14)
[00:46:29]
[00:46:29] Assembly optimizations on if available.
[00:46:29] Entering M.D.
[00:46:49] (Starting from checkpoint)
[00:46:49] Protein: p6316_sh3_with_ALA_frags
[00:46:49]
[00:46:49] Writing local files
[00:46:49] Completed 15000 out of 500000 steps (3%)
[00:46:49] Extra SSE boost OK.
CFG
[settings]
username=DarkWhite
team=32
asknet=no
bigpackets=big
machineid=1
[http]
active=no
host=localhost
port=8080
[core]
checkpoint=15
[clienttype]
type=3
Hope that's enough for ya ;)
OK, I'm a little off in the weeds here maybe? You have one -smp 2 client, and you have one non smp client.
Of course, they will be folding at different rates, with different WU's, and earning different points per day.
SMP WU's are worth a lot more than the 1 core WU's, and fold faster as well.
This says it all:
Yes, there is one space between the p and the 2, and that is as it should be.
If you want to maximize your points, you need VMware player 3.0.0 and one 4 core SMP VM + GPU. If the 4850 were running without a VM or other client, it would make about 2000 ppd. You obviously have a priority conflict.
Finish the WUs you're running on one of the VMs and the CPU client and close them. Reconfigure the remaining VM (get VM Player if you don't have it) for four cores and be sure to reconfig notfreds to run one SMP instance per four cores. Edit the .vmx file (VMware configuration file) to add the line: priority.ungrabbed = "idle". Keep the VM minimized. Run FAH gpu configuration and in the advanced config, set priority to low (slightly higher if you're using systray). You should make at least 1000 ppd more than you are currently getting.
Since you're on ATi, you're going to need to add the following environment variables:
CAL_NO_FLUSH set the value to 1
CAL_PRE_FLUSH set the value to 1
BROOK_YEILD set the value to 2
FLUSH_INTERVAL set the value to 128
If the GPU uses more than 5% of the cpu resources, increase the flush interval. I recommend no more than increments of 16. If you go too high you'll suffer VPU recovers.
Thanks ChasR, just one question.
Should the GPU running in the VM, and if so how do I set that up.
If not, where is the files I need to edit to add those lines?
Thanks much,
Darks
Run the GPU in windows. THe gpu won't run in a VM as far as I know and you wouldn't want to do it if it would anyway.
