- Mar 7, 2008
Decided to split this off from the review thread. I don't know it is the CPU necessarily, but it is the variable that has changed since the problems started. Since replacing a 10600k with a 11700k I've had 4 system crashes which resulted in it restarting immediately. No time for BSODs or anything in logs. In the time that happened I've tried 3 different ram configurations so I'm leaning towards that not being a factor.
crash 1: mining + youtube (2x8GB 3600 ram)
crash 2: mining + youtube (4x8GB 2933 ram)
crash 3: mining only (4x8GB 2933 ram)
crash 4: mining + BOINC [prime95 like CPU loading] (2x16GB 3200 ram)
The only common factor in the crashes so far is that mining was running. The same mining software and hardware was used with the 10600k without problem. What I don't know right now is if that is a factor, or just a coincidence in that I run it a lot, so the chances are increased it is running when the crash happens.
Crash 4 is interesting as it rules out one theory I had that was the system might be unstable at light CPU loads. Another theory is that it might be related to the 30 series power problem reported early in its product life, although I thought that was on the 3080 and above, and my 850W PSU is supposed to be a decent one. Also, while mining the GPU is on 41% power limit so I shouldn't be near the card's peak power.
Right now I'm running BOINC only and about to head to bed. If I get a crash without mining running, at least I can rule that out.
Key system components:
i7-11700k
Gigabyte Z490 Elite AC - bios F20d (currently latest available, but bios microcode version is not latest known)
Noctua D15 (one fan, with "silent" cable)
MSI 3070 Gaming Trio X
EVGA Supernova G2L 850W
Corsair Vengeance Pro RGB 3200 2x16GB
Other reports of instability with i9s, but I have an i7...
i7-11700k
