- Jul 31, 2004
I've got one of the (famous? notorious? no-adjective-necessary?) Rocketfish cases from Best Buy. I've replaced the case fans with low-speed Yate Loons.
Top back and side fans are exhaust. Front bottom fan is intake. The fan on the Ultra 120 Extreme is mounted on the side facing the back of the case, and pulls air through the sink towards the case fan.
I have two S1 Rev 2 sinks, a second 4850, and a Lian-Li 3x5.25"-bay 120mm fan thing coming Thursday. The S1 Rev. 2 instructions recommend case exhaust pressure higher than intake, so that air can be pulled in through the slot covers which the S1 will be behind. Would it make a noticable difference in temps to switch the bottom front case fan to exhaust, so that the whole bottom section of the case moves in from back, and out from side and front, and make the 5.25" bay fan intake, so the top is completely front-to-back over the CPU, or will the air flow mix up too much in the case anyway for two seperate "flows" to work?
