- Mar 20, 2003
- I'm now in Colorado
They do. You just dont see it because the FET sinks are larger. Since they are almost 2X as large they dont need nearly the same kind of airflow that the cheaper Aspires do.MassiveOverkill said:What I don't get is why all these high dollar PSU's don't have better cooling.
MassiveOverkill said:It's no OCZ or Fortron, but calling it junk is a little extreme.
larva said:I've got a 250W Aspire that is a Channel Well supply. It's best not to try to lump all products of a given name together, especially when you are talking about people that don't really manufacture anything, like Rosewill. They could be buying anything from Deer to Fortron, and unless you know the maker of a particular model, you just don't know much.
MassiveOverkill said:Oklahoma, my junk comment wasn't aimed at you, and you're probably right, most of the cheaper Rosewills are probably crap. It was aimed at defending this particular power supply.
But the point is dell isn't yielding their prices by using sub-standard equipment. Sure you can't afford to spend $50 dollars on a power supply if you are competing with dell dollar-for-dollar, but backing off to a less-than-first-rate supply in order to do it is not really competing.MassiveOverkill said:It's hard to sell my customers on an $80 or higher power supply. Heck, it's hard enough trying to sell them on a $50 power supply. Trying to build a computer that's competitive costwise with a Dell takes alot of homework
MassiveOverkill said:What I don't get is why all these high dollar PSU's don't have better cooling. >>>>>>>
Exactally. If they are sinked properly then they wont NEED more than one fanSusquehannock said:They have all they need. The advertisers are great at making people think
more fans are always better. A well designed, quality PSU will create less heat
for given output than a cheap generic one.
Think about it, the venerable PC Power & Cooling Turbo Cool 510w only
has one fan. While many cheap generic 550w have three or four.
Here's an oldie but goody :
Turbo-Cool 510 vs... Factsheet (*.pdf file)
And there are 550w PSU that drop lower than that at 50c. Some below 200w.
