I bought this PSU used in 2015. I never had any real problems with it until I built a x99 5820k rig with it. At that point, one of the HDD's (a Toshiba 2 TiB) began disappearing once windows loaded. It wasn't the boot drive and on a warm reboot the HDD would be found by the BIOS but disappear again once windows loaded. My initial solution was to use an external PSU to power just the Toshiba HDD and that worked. After that I tried using a molex-to-SATA power connector with the internal Rosewill Capstone 750 Watt and that worked.
Everything was fine for a while until my HP 1260d DVD-RW began exhibiting the exact same problem. I figured it was dead but on testing it on my x79 box it worked fine.
Fast forward to this month and now my Samsung 850 Pro 256 GiB SSD begins disappearing (but only under heavy gaming load, not even prime95 or orthos cause it to disappear it has to be a gaming load). Once again, I tried connecting it via a molex-to-SATA power connector and the problem disappeared.
Can power supply cables go bad? Or maybe the Rosewill Capstone 750 Watt had lousy SATA power connectors from the get-go? Or maybe it's because I live in a humid area (I once had a EIDE HDD that had to have its data cable regularly disconnected and reconnected otherwise it would disappear). Then again my x79 rig has never had any problems like this and it has all SATA HDD's, SSD's and even a DVD-ROM.
