Router running port scans.
Tebore
Toronto,Canada(I can see you....)
Hmm this is very strange my router seems to be running port scans.
Anyone have any idea why?[
XWRed1
Senior Member
Notice it keeps hitting the same port on your computer. udp 162 is snmp.
D $hady
/home/USA/NH
In the router setup, under the Log tab, you can set which computer(s) to send the logs to. You can either disable logging or set the address to the router's IP (instead of X.X.X.255, which sends it to the whole subnet). If you want, you could allow the logging and use WallWatcher (www.wallwatcher.com) to see the activity logs from the router.
