Rt Axe 7800
Benb87
Hi id like to know what are good settings for gaming? Also should I return this router and get a alternative one if so what router do you recommend for 20 wifi devices and one Ethernet PC?
I have a higher end Asus router and left it at default settings. You can switch between profiles to prioritize Wi-fi packets, but I didn't notice much as far as lower ping or anything in my network (also about 20 connected devices).
Are you wired or wifi connected to this router?
Ok thanks is the 8700 good enough for gaming low latency ei cod mw3 warno?
Here's the link to my router:
I know exactly what it is...just making sure you didn't typo again. ;)
Don't want to answer the question of hardwired or wifi or............................? :shrug:
