Check in the Registry (Start | Run | Type regedit and click OK) under the following Key...
HKEY_LOCAL_MACHINE | Software | Microsoft | Windows | CurrentVersion | Run
In the RH pane, delete the entries: BookedSpace and/or Bsx3 (BS3 variant)...also, any Bsx5 (Bsx5 variant) entries. Restart the computer and you should be able to delete the rem00001.dll, bs2.dll, bs3.dll and/or bsx5.dll file(s) from the WinNT directory (although they may need to be unregistered first, and they may be able to be deleted without restarting). You could probably also delete these additional Keys (if found) from the Registry...
HKEY_LOCAL_MACHINE | Software | Remanent...and:
HKEY_LOCAL_MACHINE | Software | BookedSpace
Make sure to at least export the above Keys before deleting any entries, just in case you need to merge any or all of them back to their original locations.
