i have a 120mm fan on the buttom front of my case that is blowing air from outside the case, over the radiator (in the case), and into the case
3 fans in the back pulling air out (including psu fan, all 80mm), then i have another 80mm putting air in on the side of the case, i think im going to get another 80mm and mount it next to that one for blowing air in
no water additives, just distilled water
i did mount the waterblock to the cpu correctly using artic silver2, i read the directions
i was told i could put Rubbing Alcohol in the line, which would improve cooling performance, but kinda shakey on that
also, i think lots of the air in my radiator (or cooling coil), is getting stopped cause the 120mm fan doesn thave enough pressure, im thinking ill mount another 120 mm so i have one blowing air on the radiator, and one sucking through it, i dunno if this will work good, but it might
also, im using a rio180 pump, and water flow is probably a little to slow, so im going to call becooling and see if i can get a trade in with teir danner 280gph + 1 foot lift pump, i think thatll help out greatly
thanks for the replys
-warflyr
