- Aug 24, 2001
Hello i have a 1400 mhz amd system with 512 megs of DDR ram and all the other stuff but no HDD.
Would it be possible to make a ram drive and install windows 98 (how much space do you need to install 98?) or mabe an alternative smaller OS from cd then use the comp as usual? All i want to do is search the net.
I know everything would be wiped once the box was shut down and i'd have to install again but would this work?
Does anyone have any tips, input, ect?
