ryzen 3.9ghz temp values
emremertozcan
Hi everyone, my spec; ryzen 1700 @3.9gHz,asus prime x370, crucial 8x2G 2400mhz cl15 ram, and my cooler is xigmatek sd1264b. I am at @3.9ghz with 1.33750V and these are my temps;
Idle: between 35-42, average is 36-37
surfin on the internet: min:39,average 43-44 max:51
Aida64: 1 hour test, max is 76.1, average is 74-75
Battlefield 1: betwen 56-63,64 average is 60-61
I couldnt decide if my temps are good, i am someone new to overclock. I am waiting for your comments, should i keep my oc settings or not. Thank you all!!
Blaylock
Go Blue!
Your temps look good. If you're stable I'd stick with it. From all the reports I've read you wont begin to throttle until you're into the 90's C, but I would keep it under 80c just for safety's sake. We still don't know a whole lot about this chip after all.
Woomack
Benching Team Leader
95*C should be throttle point but I see that my CPU generates errors ( or simply crashes in some operations ) at ~90*C after OC. ~75*C under load is perfectly fine. I get a bit lower temps on my 1700X and Noctua cooler. 3.95GHz is max fully stable in my case.
