- Feb 18, 2007
With a very small vcore bump doing > 4.6 GHz. Was able to validate a CPU-Z screenshot at 4.7 on stock volts (though my MB may be auto-bumping it..?) but R20 immediately crashed that. So, I scaled back a bit and went up a bit on voltage. Then I scaled the volts back till it became unstable. Then increased it by two incremental notches. So far I've been able to run Cinebench four times without a hitch. Gained almost 600 points on there vs stock! Pretty awesome IMO.
Very comfortable temps on my 2x120 cooler master closed loop / aio system.
Should I push it? Do my voltage readings look normal? Am I doing anything wrong? Last OC was on the 775 platform.
From poking around google... seems like maybe I got lucky with this chip? Or maybe I'm finding old results.
Feedback, tips appreciated.
3600 @ 4624 MHz Stable enough to run R20 four times --> https://valid.x86.fr/1ss78b 4156 In CB R20, 20pts shy of a 600pt gain over stock.
3600 @ 4702 MHz Validated but unstable --> https://valid.x86.fr/ikl2pc (I'm sure with more voltage it is totally do-able)
Don't know how far I want to push this. Need this system \ chip to last a long time!
