- Sep 15, 2015
- Pensacola, Fl
Looking to start building a parts list for my loop, potentially I'm going to include the VRM's and NB(http://www.overclock.net/t/1468642/how-to-watercool-the-asus-990fx-sabertooth-rev2-0-vrms-and-nb). Any suggestions or components you might recommend for my build would be greatly appreciated. I don't intend on including my gpu in the loop, I may purchase a second for sli down the line though, so I need to maintain good airflow. Anything I'm forgetting, or am completely unaware that I should be purchasing? And of course if you see a way for me to save a few bucks or a headache, please say so. Thanks!
The blocks I plan to get;
VRM opt.1http://www.performance-pcs.com/new-watercool-heatkiller-swx-a4-lt.html
VRM opt.2http://shop.anfi-tec.de/product_info.php/info/p244_PWM-068-Asus-Sabertooth-990FX-R2-0.html
NB opt.1http://shop.anfi-tec.de/product_info.php/info/p88_Anfi-tec-UCD-nano.html
NB opt.2http://www.performance-pcs.com/watercool-heatkiller-nsb-rev3-0-lt.html
CPU opt.1 http://www.performance-pcs.com/ek-supremacy-mx-cpu-waterblock-amd-acetal-21426.html
CPU opt.2 http://www.performance-pcs.com/phob...-939-am2-am3-silver-nickel-black-edition.html
CPU opt.3 http://www.performance-pcs.com/phob...-939-am2-am3-silver-nickel-brass-edition.html
The rads I plan to get;
Top exhaust http://www.performance-pcs.com/koolance-radiator-2x140mm-copper-high-flow-no-nozzles.html
Rear exhaust opt. http://www.performance-pcs.com/koolance-radiator-1x120mm-copper-vert-no-nozzles.html
Front intake opt.1 http://www.performance-pcs.com/alphacool-nexxxos-ut60-full-copper-280mm.html
Front intake opt.2 http://www.performance-pcs.com/phobya-g-changer-280mm.html
The pump/res I plan to get;
opt.1 http://www.performance-pcs.com/ek-xres-100-revo-d5-pwm-incl-pump.html
opt.2 http://www.performance-pcs.com/phob...ol-lighttower-all-in-one-reservoir-combo.html
The fittings I plan to get;
http://www.performance-pcs.com/new-ek-hd-adapter-12-16mm-black.html
http://koolance.com/fitting-single-compression-for-16mm-5-8in-rigid-tubing-fit-v16rt-bk
The tubing I plan to get;
http://www.performance-pcs.com/new-ek-hd-tube-12-16mm-500mm-19-5-2-pcs.html
