60-62 is really hot! When does it run this hot? I hope only under full load like Prime95 or SETI. I would make sure the CPU is in the board flat, raise the handle on the socket and put mild pressure on the corners while you lock it back down. Make sure the cooler it sitting as flat as you see. I have a 900 Tbird running at 1050mhz, 1.85v, 10 x 105mhz, and I bought 4 different fans to see which worked best, the highest temp I ever got was 51c under full load. I have a Global Win FOP38, very very loud, and the temp never goes above 39c, idles at 29-31c. I have heard the Orb coolers do not work as well as some think. Of the coolers I have personally tried are CoolerMaster CB5-5G12, small copper cooler, suprised me for the size, max temp 49c, CoolerMaster DP5-6H51, normal looking aluminum cooler, max temp 51c, MWave cooler from
www.mwave.com, looks like the CM DP5-6H51 with a little bigger fan, max temp 48c, and of course the Global Win FOP 38, very loud, larger the the others, max temp 39c. All of these were taken under full load with Arctic Silver thermal compound, which I did not notice a huge temperature difference with.
