Samsung 1GB PC2100 and Abit KR7A-133RAID mobo
XiveX
Cleveland, OH
I am going to buy the ABIT KR7A-133 RAID motherboard and have a few questions for you regarding the type of DDR memory I can use in it. I am looking at buying a pair of 1 GB DDR PC2100 Samsung memory modules. The question I have is regarding the bits of the RAM. Will your board support THIS PARTICULAR chip? Here are the specs on it:
Samsung 1GB (1024MB) DDR SDRAM, 266MHz, PC2100, 128x72, 2.5V, Non-Parity, ECC Registered (Recommended for Server use), CL2, 184-pin. 6 layer PCB to enhance stability and performance.
Industry Standard, guarantee to work on ALL SYSTEMS, that supports 72bit ECC resgistered RAM. Windows 2000 and XP ready.
Here is a link to it if you need more info:
http://www.ocsystem.com/sam1gbpcddrs.html
What concerns me is the part about "128bit x 72 bit". This seems like a bit out there for a RAM chip, and I wanted to make sure that your board supports a 72bit ECC registered RAM chip.
What do these "bits" mean? WIll a DDR motherboard support any set of DDR chips? (ie 64x64, 64x72, 128x72, etc.)
Thanks a bunch!
Xive
