- Jan 4, 2005
In my impression, SanDisk is well known brand in Taiwan for years.
My first SanDisk product was CF card for digital SLR camera.
After another, I also used or researched other brands CF and SD card. I think memory card is key field of SanDisk.
SanDisk has wide range product lines of high spec. memory card. It’s also one of few brands to have SLC products.
Previously, I saw some SanDisk SSD products from internet were SATA2 and mSATA.
I felt they more focus on NoteBook and didn’t see any SATA3 high bandwidth product yet.
However, in March, I started to see more news about SanDisk SATA3 SSD in internet and market.
For current competitive SSD market, launching SSD this stage needs to own real strength and right position.
First of all, let’s look at SanDisk Extreme SSD packing.
It’s same design style with his memory card. The simple design uses black as main color to combine with red lines or characters.
Contents
Left side is SanDisk Extreme 240GB and sticker. Right side is multi-languages products manual.
If they can bundle 2.5” to 3.5” adapter, that would be better.
It’s 2.5” and the capacity is 240GB. In official spec, max Sequential Read/Write is 550/520 MB/s.
Max random Read/ Write is 39K/83K IOPS. It’s the SATA3 SSD highest spec in the market so far.
The model name is SDSSDX-240G-G25. This series has 120, 240 and 480GB.
It’s glossy black metal shell. The texture of outlook is elegant.
Controller chip is SandForce SF-2281. This chip has launched almost one year. Many major brands SSD are also using SF-2281.
Backside sticker shows all safety certificate and information.
The screws are under sticker which is different with general design.
If you want to see controller and NAND Flash inside, you can search the pictures from internet.
As warranty and hardware safety, I recommend you to keep it as original.
Lower right is SATA3 and power connector. It’s same as SATA1 or SATA2.
You need to check the packing or product spec to know if it’s SATA3 SSD.
Screw holes are 2.5” standard. It supports NoteBook.
Now, many PC Case also support 2.5” rack. 2.5” to 3.5” adaptor is not really necessary for PC users.
SanDisk Extreme uses SandForce SF-2281 controller. It’s very popular SATA3 SSD controller.
It uses anDisk 24nm Synchronize NAND Flash. The individual IC is 32GB.
NAND Flash IC is very special. Normally, SandForce SF-2281 bundles with Intel or Micron IC.
For the performance, let’s follow on the test result below.
First, I use Intel DeskTop platform. It’s GIGABYTE latest Z77X-UD5H-WB WIFI.
It supprts 3 PCI-E X16, 3 PCI-E X1 and 1 PCI. It’s good extensibility in ATX size.
Z77 built-in GPU supports simultaneously three outputs. It’s also first time native support USB 3.0.
Exclusive BT4.0 and Wi-Fi PCI-E card enhance connection between PC and mobile devices indoor.
Intel Z77 is latest mid to high end chipset. It’s getting popular.
Intel chipset always gets better I/O transfer rate. SATA3 SSD can have better performance on it.
Test Configuration
CPU: Intel Core i7-3770K
MB: Z77X-UD5H-WB WIFI
DRAM: CORSAIR DOMINATOR-GT CMT16GX3M4X2133C9
VGA: Intel HD Graphics 4000
HD: SanDisk Extreme 240GB / TOSHIBA 750GB
POWER: CORSAIR AX650W
Cooler: Intel Original Cooler
OS: Windows7 Ultimate 64bit
Single SanDisk Extreme 240GB install at white SATA3.
I set it as non-OS drive without any data to test performance on Intel Z77 platform.
HD Tune Pro 5.00
Black Size is special function of this software. Left side is default 64K and right side is 1MB.
64K - Read - Average 339.5 MB/s Access Time 0.134ms
1MB - Read - Average 516.0 MB/s Access Time 0.135ms
Contents
Test Configuration
HD Tune Pro 5.00
