- Aug 1, 2003
- E600000 - E60000FF
yes it will but you MUST entire bios on the new board before you ever let it try to boot and enable the raid function, or it could break your array
All the boards out now are flawed. its in the chipset. With that said, since you are not using the affected ports, there is no worry to buy now IF you can find a motherboard.Hello,
I want to buy a new system now, and the processor in mind is the i5, hence i need the Sandy Bridge motherboard.
My question is, given I know for sure, that I will never be using other ports than the two SATA 3, 6Gb/s, will I then have to change motherboard in april when the replacements are released? Or am I just fine, as I dont use the affected ports?
If the aswer to the upper question is yes, I will have to change in april, then are there any replacement, another motherboard I can purchase which has no flaws suiting the i5? Or any other recommendations?
/Henrik
Hello,
/Henrik
The problem is only the SATA 2.0 ports. If you disable them or are not running anything off from the SATA 2.0 port they you wouldn’t be affected by the issue at all. There are some system manufacturers who have been given the go ahead from Intel® to continue to make products with the old “B2” stepping as long as they insure that nothing is run off from the SATA 2.0 ports.
Intel would prefer that you return any board that you might have with the “B2” on it if only to get a board that there is no chance of having a problem with. For your Information you should start to see the new “B3” stepping boards hitting the market by mid-March.
Christian Wood
Intel Enthusiast Team
hmmmm ok, so just go into bios and set it as raid. sound like a plan thx man
No biggie if I lose it, just got some VMware 7 and now I'm thinking about switching to Linux hehe
I have an ASRock P67 Extreme 6 in review right now. It's quite impressive, especially for the price. It should be published sometime next week.
Great! I can't wait to read it!!
Just published, hope you like it.
Thanks!
I found a p67 biostar h67 biostar and a p67 msi on newegg.is this it? Are they coming out?
