Hey guys, I just got a new system. Here are the specs
AMD Phenom II X6 1090T BE (Stock)
Asus M4A89GTD PRO/USB3
Sapphire Radeon HD 6870 1 gb (stock)
Corsair CMX4GX3M2A1600C9 8GB total (4 2 gb kits)
Corsair TX650W
WD Green 1 TB
CoolerMaster 430 elite black
The thing is after I had a clean install of Win 7 64 bit, I ran 3dmark06 and I got a score of 19740 and a Vantage score of around 16430. Is this normal for my rig? Then I ran Heaven Benchmark v2.1, was getting 35-40 ish fps in it, and after sometime in it, it crashed with a BSOD stating an error with atikmpag.sys. This was 'apparently' due to the fact that the card was on a grey slot with no switch card in the blue slot. Following the mobo manual, I placed the card in the blue slot with the switch card in the grey slot to get 'optimum' x16 speed for PCI-E 2.0. After that I fired up mark06 and i got a score of 18657. But the worse performance was in Vantage where I lost 3000 points (13000 points after the switch). The funny thing is Heaven's Benchmark ran fine without crashing and I kept it looping for a couple of hours. But again when I started benching in Heavens. my fps dropped a lot compared to what I was getting earlier ( getting 28 now ). I tested to see if my graphic card was faulty, so I ran Furmark, OCCT GPU test and it passed in both. I ran memtest86+(7 hours), Prime95( kept it for 9 hours) and windows memory diagnostic and it passed in all of them. So my memory is fine too, I think. I tried running OCCT Power supply test and 20-25 into it, it crashed with a BSOD and restarted. Then I re ran the test and this time it worked fine with no crashes! But since power supply test puts load on everything in the system, should I conclude that my psu is faulty? or is my motherboard faulty? Can you please help me on this..Its been only a few days since I purchased it.
Thanks...
Current status: I reinstalled Win 7 and ran the 3dmarks 06 and vantage. In 06, I got a score of 19870 and in Vantage I got 15653. Even though I got a bit higher score in 06, my Vantage score is still lower than what I got at first. Any headers to this. Also I have just noticed that I dont get any beeps from my motherboard on booting
. But everything else seems to be fine. Does this indicate any problem?
Corsair TX650W
WD Green 1 TB
Thanks...
