SATA VS IDE(PATA) DVD/CR-RW drives/burners
Omari79
which one should i get?
I do understand that SATA allows for more air flow because of the thin cable but the real question for me is this
1- Is it faster at installing games?
2- Is it reliable?
3- If SATA is the way to go, any particular brand you advice me to get? LG, SAMSUNG, ASUS?
Thanks in advance
Vipersfate
Colorado
Well, CDs can only read at a certain speed. Going IDE or SATA IMO doesn't really make a difference. I find whatever's on sale, and buy it. Asus one I had went bad after 2 months, rma took 7 days exactly, but they sent me an IDE back. I didn't care, and it works good :D
dgb303
5280, USA
IDE is older, many newer mobo's don't even support it. Performance differences will be minimal for most use, which really leaves the choice up to you and your wallet.
bing
Low Profile Senior
Indonesia
Not always, sata its just the electrical interface, final speed wise still depends on the mechanical part. But with current optical drives manufacturers making priority on sata interace rather than ide, I would say "generally" and safe to say sata model is better.
2- Is it reliable?
You mean sata interface ? Its already settled quite sometime now, and yes, it is reliable. Physically, the sata cable is much better than ide, those IDE 80 cables and it's connector are prone to error and troubles if you plug & pull it alot.
Samsung or Pioneer should be fine, LG not too bad too. Most Asus now is rebranded Pioneer or others, they stopped producing their own optical years ago.
athlonhead
Sata is the newer technology. That is what I went with for my dvd burner.
Lite on is a good brand.
