- Jul 22, 2002
- ~50 miles north of Chicago
I'm starting to same money for a dual Socket A motherboard. This will take a while because I have no DDR RAM, but I need to know which I should draw my sights on. I've done my homework as best I could, but seeing as the market for 760MPX boards (the chipset I'm looking for, which I think is the most recent) aren't as widespread as say, KT333s, I haven't been able to gather all the info I need. Here's what I'm looking for in my future motherboard:
*support for some mild overclocking (not the type you would need PC3500 for. I'm talking something like bumping the FSB to 140.)
*Support for non-registered RAM. It's OK if it will only take 2 DIMMs worth, because I'm only planning to use 2 sticks.
Integrated sound isn't required as I have a Live Xgamer which I love. Lots of fan headers would also be a good thing, as the case I'm going to put this in will have a lot of fans. (I'm the kind of guy who dosen't mind a Delta 38, as long as it keeps my Athlon(s) from burning up).
Thanks in Advance,
Doorbasher
-----Insert witty sig here.-----
Thanks in Advance,
Doorbasher
