Screensaver not working
redduc900
Inactive Moderator
Portland, OR
Here are some workarounds, however the one that seems to work the best is manually setting your screensaver via the Registry. Check your settings here...Start | Run | Type regedit and hit OK | Expand the following Key:
HKEY_CURRENT_USER | Control Panel | Desktop
Check to make sure the following entry exists in the RH pane...
Scrnsave.exe = C:\Windows\System32\logon.scr
Verify your 'Time' while there as well and choose the string value accordingly...
ScreenSaveTimeOut = (set your preference)
Also, make sure none of the screensavers are wrapped in double quotes as in...
""c:\windows\system32\screensavername.scr""
...and try adding: ss in front of the screensaver name or totally rename it.
Screen Saver Disable and Screen Saver Enable (Line 51)
Change Screensaver Automatically in the Registry (Line 97)
Screen Saver May Not Start in Windows XP ;)
