Sata Drive won't burn CD/DVD
Hey there readers. I got a new dvd burner a few weeks ago, ASUS DRW-2014L1T, and it won't burn any CDs, and I am guessing no DVDs either, but have not tested DVDs. It is a sata drive, my only sata optical drive, and my system is an ASUS P5B-E board with a C2D E6400. It reads cds and dvds fine, just has problems burning. Here is one log file from Nero:
In the output window, it stated a DMA-driver error and CRC error. I have tried burning many CDs with lower and lower speeds with no luck. The media is TDK CD-R 48x. I have also received a different error from nero, here is the log from that error.
and the output to the window for that error was Invalid block address and invalid write state, session fixation error. I have updated the firmware on the burner from asus's website, and updated the chipset drivers for my mobo from asus's website, although the Matrix Storage Manager Driver wouldn't update. Anyone have any help for me?
Code:
BdON
1C82-0000-19E5-MAAX-4007-0161-****
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'D:\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 1:54:32 PM
NT-SPTI used
Nero Version: 7.5.1.1
Internal Version: 7, 5, 1, 1
(Nero Express)
Recorder: <ASUS DRW-2014L1T> Version: 1.02 - HA 1 TA 1 - 7.5.1.1
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <ASUS DRW-2014L1T >Version: 1.02 - HA 1 TA 1 - 7.5.1.1
=== Scsi-Device-Map ===
CdRomPeripheral : _NEC DVD_RW ND-2500A atapi Port 1 ID 0 DMA: On
DiskPeripheral : ST3320620AS atapi Port 2 ID 0 DMA: On
CdRomPeripheral : ASUS DRW-2014L1T atapi Port 3 ID 0 DMA: On
=== CDRom-Device-Map ===
ASUS DRW-2014L1T E: CDRom1
_NEC DVD_RW ND-2500A G: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1023MB (1047724kB)
Free physical memory: 492MB (504060kB)
Memory in use : 51 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
15.3.2008
CD-ROM (ISO)
10:45:24 AM #1 Text 0 File Isodoc.cpp, Line 6510
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
10:45:24 AM #2 Text 0 File Burncd.cpp, Line 3129
ASUS DRW-2014L1T
FlextraLink activated
10:45:24 AM #3 Text 0 File ThreadedTransfer.cpp, Line 540
ReadBuffer-Pipe got 81920KB of Memory
10:45:24 AM #4 Text 0 File Reader.cpp, Line 126
Reader running
10:45:24 AM #5 Text 0 File Writer.cpp, Line 123
Writer E: ASUS DRW-2014L1T running
10:45:24 AM #6 ISO9660GEN -11 File Geniso.cpp, Line 3313
First writeable address = 0 (0x00000000)
10:45:24 AM #7 Text 0 File Burncd.cpp, Line 3443
Turn on Track-At-Once, using CD-R/RW media
10:45:25 AM #8 Text 0 File DlgWaitCD.cpp, Line 300
Last possible write address on media: 359845 ( 79:59.70)
Last address to be written: 1526 ( 0:22.26)
10:45:25 AM #9 Text 0 File DlgWaitCD.cpp, Line 312
Write in overburning mode: NO (enabled: CD)
10:45:25 AM #10 Text 0 File DlgWaitCD.cpp, Line 2851
Recorder: ASUS DRW-2014L1T;
CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
ATIP Data:
Special Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
10:45:25 AM #11 Text 0 File DlgWaitCD.cpp, Line 484
>>> Protocol of DlgWaitCD activities: <<<
10:45:25 AM #12 Text 0 File ThreadedTransferInterface.cpp, Line 863
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1527 (1527) = #1527/0:20.27
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1525 blocks [E: ASUS DRW-2014L1T]
10:45:25 AM #13 Text 0 File ThreadedTransferInterface.cpp, Line 1079
Prepare recorder [E: ASUS DRW-2014L1T] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 3434496, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x41 | 1527 | -150 | 0x00
0 | 1 | 1 | 0x41 | 1527 | 0 | 0x00
1527 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
10:45:25 AM #14 Text 0 File ThreadedTransferInterface.cpp, Line 1149
Removed 2 run-out blocks from end of track 1. Length: 1527 -> 1525.
10:45:25 AM #15 Text 0 File SCSIPassThrough.cpp, Line 39
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
10:45:25 AM #16 Phase 24 File dlgbrnst.cpp, Line 1730
Caching of files started
10:45:25 AM #17 Text 0 File Burncd.cpp, Line 4274
Cache writing successful.
10:45:25 AM #18 Phase 25 File dlgbrnst.cpp, Line 1730
Caching of files completed
10:45:25 AM #19 Phase 36 File dlgbrnst.cpp, Line 1730
Burn process started at 48x (7,200 KB/s)
10:45:25 AM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2746
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
10:45:25 AM #21 Text 0 File MMC.cpp, Line 22129
Set BUFE: FlextraLink -> ON
10:45:37 AM #22 SPTI -1502 File SCSIPassThrough.cpp, Line 291
E: CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1502)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x08
Sense Qual: 0x03
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Area: 0x70 00 04 00 00 00 00 0A 00 00 00 00 08 03
Buffer x0bee0000: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
10:45:37 AM #23 CDR -1502 File Writer.cpp, Line 312
DMA-driver error, CRC error
E: ASUS DRW-2014L1T
10:45:37 AM #24 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
10:45:40 AM #25 CDR -201 File WriterStatus.cpp, Line 200
Invalid write state
E: ASUS DRW-2014L1T
10:45:40 AM #26 TRANSFER -18 File WriterStatus.cpp, Line 200
Could not perform EndTrack
10:45:40 AM #27 Text 0 File MMC.cpp, Line 16933
<ASUS DRW-2014L1T > start Close Session
10:45:53 AM #28 SPTI -1176 File SCSIPassThrough.cpp, Line 291
E: CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1176)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x72
Sense Qual: 0x01
CDB Data: 0x00 00 00 00 00 00 00 00 00 00 00 00
Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 72 01
10:45:53 AM #29 CDR -1176 File WriterStatus.cpp, Line 250
Session fixation error
E: ASUS DRW-2014L1T
10:45:53 AM #30 TRANSFER -19 File WriterStatus.cpp, Line 250
Could not perform Fixation
10:45:53 AM #31 Text 0 File WriterStatus.cpp, Line 259
falling back to disc fixation
10:45:53 AM #32 Text 0 File MMC.cpp, Line 16933
10:46:22 AM #33 SPTI -500 File SCSIPassThrough.cpp, Line 291
E: CdRom1: SCSIStatus(x00) WinError(1117) NeroError(-500)
Sense Key: 0x00 (KEY_NO_SENSE)
Sense Code: 0x00
Sense Qual: 0x00
Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00
10:46:22 AM #34 CDR -500 File WriterStatus.cpp, Line 250
SCSI command aborted
E: ASUS DRW-2014L1T
10:46:22 AM #35 TRANSFER -19 File WriterStatus.cpp, Line 250
10:46:22 AM #36 SPTI -1023 File SCSIPassThrough.cpp, Line 291
E: CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1023)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x2C
Sense Qual: 0x00
CDB Data: 0x55 10 00 00 00 00 00 00 3C 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 2C
Buffer x05119600: Len x3c
0x00 00 00 00 00 00 00 00 05 32 01 C4 08 00 00 00
0x00 00 00 00 00 00 00 96 00 00 00 00 00 00 00 00
10:46:22 AM #37 Phase 38 File dlgbrnst.cpp, Line 1730
Burn process failed at 48x (7,200 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=9464 bytes, created 12/4/2007 1:38:10 PM
File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 12/4/2007 1:38:08 PM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Code:
BdON
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
(Nero Express)
AutoRun : 1
Excluded drive IDs:
BUFE : 0
Free physical memory: 427MB (437492kB)
Memory in use : 58 %
Use Inquiry : 1
15.3.2008
CD-ROM (ISO)
11:04:30 AM #1 Text 0 File Isodoc.cpp, Line 6510
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : TAO
Mode : 1
Joliet : TRUE
11:04:30 AM #2 Text 0 File Burncd.cpp, Line 3129
ASUS DRW-2014L1T
11:04:30 AM #3 Text 0 File ThreadedTransfer.cpp, Line 540
11:04:30 AM #4 Text 0 File Reader.cpp, Line 126
Reader running
11:04:30 AM #5 Text 0 File Writer.cpp, Line 123
11:04:30 AM #6 ISO9660GEN -11 File Geniso.cpp, Line 3313
11:04:30 AM #7 Text 0 File Burncd.cpp, Line 3443
11:04:32 AM #8 Text 0 File DlgWaitCD.cpp, Line 300
Last address to be written: 9672 ( 2:10.72)
11:04:32 AM #9 Text 0 File DlgWaitCD.cpp, Line 312
11:04:32 AM #10 Text 0 File DlgWaitCD.cpp, Line 2851
ATIP Data:
11:04:32 AM #11 Text 0 File DlgWaitCD.cpp, Line 484
11:04:33 AM #12 Text 0 File ThreadedTransferInterface.cpp, Line 863
original disc pos #0 + 9673 (9673) = #9673/2:8.73
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 9671 blocks [E: ASUS DRW-2014L1T]
11:04:34 AM #13 Text 0 File ThreadedTransferInterface.cpp, Line 1079
DAO infos:
MCN: ""
Tracks 2 to 2: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 20117504, ISRC ""
DAO layout:
-150 | 2 | 0 | 0x41 | 9673 | -150 | 0x00
0 | 2 | 1 | 0x41 | 9673 | 0 | 0x00
9673 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
11:04:34 AM #14 Text 0 File ThreadedTransferInterface.cpp, Line 1149
Removed 2 run-out blocks from end of track 2. Length: 9673 -> 9671.
11:04:34 AM #15 Text 0 File SCSIPassThrough.cpp, Line 39
11:04:34 AM #16 Phase 24 File dlgbrnst.cpp, Line 1730
11:04:34 AM #17 Text 0 File Burncd.cpp, Line 4274
11:04:34 AM #18 Phase 25 File dlgbrnst.cpp, Line 1730
11:04:34 AM #19 Phase 36 File dlgbrnst.cpp, Line 1730
11:04:34 AM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2746
11:04:34 AM #21 Text 0 File MMC.cpp, Line 22129
11:04:37 AM #22 SPTI -1064 File SCSIPassThrough.cpp, Line 291
E: CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1064)
Sense Code: 0x21
Sense Qual: 0x02
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 21 02
11:04:37 AM #23 CDR -1064 File Writer.cpp, Line 312
E: ASUS DRW-2014L1T
11:04:37 AM #24 Text 0 File ThreadedTransfer.cpp, Line 229
11:04:38 AM #25 CDR -201 File WriterStatus.cpp, Line 200
Invalid write state
E: ASUS DRW-2014L1T
11:04:38 AM #26 TRANSFER -18 File WriterStatus.cpp, Line 200
11:04:38 AM #27 Text 0 File MMC.cpp, Line 16933
11:04:38 AM #28 SPTI -1176 File SCSIPassThrough.cpp, Line 291
Sense Code: 0x72
Sense Qual: 0x03
CDB Data: 0x5B 01 02 00 00 00 00 00 00 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 72 03
11:04:38 AM #29 CDR -1176 File WriterStatus.cpp, Line 250
E: ASUS DRW-2014L1T
11:04:38 AM #30 TRANSFER -19 File WriterStatus.cpp, Line 250
11:04:38 AM #31 Text 0 File WriterStatus.cpp, Line 259
11:04:38 AM #32 Phase 38 File dlgbrnst.cpp, Line 1730
Existing drivers:
Registry Keys:
