SCSI problem
silent bob
Team 32 Folding Ghetto Hanging PC Senior
in "The Cave "
I can not get my Yamaha 2100SZ to be recognized and my scsi card(P.E. Logics) either ,they worked befor the format and now they dont ,I have loaded all the drivers I can find and still no luck,am I just missing something? and what burning software can I use for this application ? it would have to recognize my pci scsi card and then what?
thanks
steve
chk the cable/jump;er on drive.
I just redid an ide raid set up on different channels, well i had to put the jumper to cable select for the controller to read them.. Nothing else worked. RThis might work for u.
I'm not familiar with the card, but are you getting a SCSI BIOS screen on bootup? If the card isn't recognized by the system, Windows won't either.
are you using Windows XP? because the support in Windows XP for Scsi devices is very bad, that's why i switched back to Windows 2000
