Scsi Raid Vs Ide
zabomb4163
http://www.xbitlabs.com/storage/10000-scsi/ :
10,000 rpm Fujitsu MAN3367MP
write max: 42
read max : 59
------------------------------------- total cost 200$ for a 36 gig or 5.55 per gig--------then buy a SCSI raid controller for 300+
WD
Average read: 40.6
average write: 23.3
write at begining: 29
read at begining: 49
------------------------------cost 116 for an 80 or 1.45 a gig
conclusion --------SCSI cost 3x for the same capacity. Is one SCSI as fast as 3 IDE hd's on RAID ????????
No, but the seek times are about 3 times faster. Reliability and durability are also unsurpassed with SCSI.
but one could purchase 3 IDE hard drives and put them onto RAID3 and achieve SCSI reliabily while still remaining cheaper per gig.
Average access and seek are two different things. A 15K RPM SCSI drive has about 3ms seek while IDE is still around 9-13ms.
i think thats the tech spec of the hd. could you find me a real world test showing a 3ms seek time?
If you plan on using Windows XP Pro/Home, you may want to consider that many people have problems with SCSI and XP.
Replace "SCSI" with "drives designed to do so" and I'd agree ;)
SCSI drives are not built well because they are SCSI, but because they were meant to live up to higher standards in the environment where they mostly likely will go into, servers!
Now, zabomb4163, what are you trying to argue? That it makes more sense to put an IDE drive in a modern desktop, especially for someone $ conscious? That's not in doubt by anybody, I think.
And no matter how cheap and fast IDE is you still can't hook a dozen of them up to a computer that's 10 feet away. That's what SCSI was meant to accomplish, not be the better bang for the buck in econo desktops.
I simply started this thread because recently i had flammed by half a dozen forum members for saying IDE regardless of cost was a more effective method of storage.
people in the thread said that IDE was not even close to the performace of SCSI which ive found to be completely untrue. I agree in a server situation SCSI is superior because of its ability to handle multiple request more efficiently.
But in a desktop PC is IDE the best ?
yeah the NTFS file system is the problem there. im about 100% sure, but correct me if im wrong, also would it still work with XP Pro and fat32 ?
It's not best, it's the more rational choice if $ is a factor.
I've dropped SCSI ever since I upgraded from a 133MHZ Pentium. Back then full speed IDE read/write operation pretty much maxed out the processor. That was really the only benefit, less CPU usage. In modern PCs its not even a factor.
