Scythe Ninja Plus Rev B CPU Cooler
dkizzy
PA
anyone a big fan of this thing? whats the performance like? Is it true the tuniq 120 and the Noctua are the best air cooling units?
The performance is quite good and I can say on par with tuniq and noctua. Designed to be used with low noise fan. Rev B comes with a more powerful 49.cfm fan. I'm using it and I'm quite satisfied with the performance.
depends what situation you want to use the ninja in.
I dont recomend using it if your gonna be pushing vcore up past 1.55 , 1.6 because the loads temps of the core hang around 60 degrees.
The infinity works a bit better, shaves of about 2-3 degrees on the core at the same specs but requires a louder higher cfm fan because of the tight fins.
The Tuniq owns because it just does:beer: pop it in, pump up the voltage and watch the temps, at 1.6v load should be about 52-55 on the core.
(assuming amd64 cpu)
Its great, currently i am using it with a TT 120 (its crap) but im getting 26-28 idle and 44 max load on system in sig
OH, and BTW: I love the winter
I'm using one on my E6300 overclocked to 2.8ghz, at full load my temps are 60 on one core and 55 on the other(Idle 44/39). Don't remember the temps from before the OC, but I believe at full load it was 41/35 and idle was somewhere around 28/33
