i have a p3 700 on a se6 mobo need to o\c any bod know the settings to do so i have had the chip o\c on a gigabite 2000 and it worked fine helpiiiiiiiiiiii
Im new but i will try and help you are you using a abit se6 motherboard??
if so im using the same motherboard with a p3 700@933 v 1.75 the settings i used were in the soft menu i put the cpu voltage on user define and set it to 1.75 anything less pc just hung then i set the cpu to 900/133 setting and it gave me the 933 now i could of gone to custum settings and done the 7 x 125 fsb and all that but i wasnt 100% sure on how to set it plus the way i first tryed worked fine so i left it at that try using the same settings as i tryed u might have some luck
