SE6 voltage
MisterQ
hey does anyone know how I can get higher votages b/c my celery 600 can run 900 on my other board where i had a slocket card and had it at 1.85v and I am limited to 1.7v max on the SE6
If you do a search back several months for "abit bios reflash" there are some descriptions of the reflash trick for the bh6 board I believe. I did find one of these that worked on my bx6 R2, so you might get lucky too. (I seem to recall that there was a short command line extension to be used when reflashing the bios and a longer one. The short did not work for me, but the longer one did.)
anvil
The BIOS reflashing trick is not known to work on the SE6. So you are faced with doing the pin trick on the CPU. That is what I had to do to get my SE6 to allow voltage high enough to reach 933 with my PIII 700 cB0.
