Search for replacement mechanical keyboard
Tech Tweaker
Well, after my G710+ killed itself, and then me killing it some more I'm looking for a replacement.
At the moment, considering either another G710+, or a G610 Orion Brown. Not sure which is better though. Or if I should be looking at something else entirely. Oh how I missed my LCD screen from my G510s when I was using the G710+. If they made a mechanical keyboard with the little LCD screen for temperature readouts, CPU and Memory usage, etc, I'd buy that if it were within my budget.
Budget range is $40-70, so of course whatever I end up buying will likely be used.
