searching in a pdf file???
elfaii
goodafternoon,
do anyone knows how i can search a word in a pdf file without to look all text each time to get the word
i had install acrobat reader and i can't work with the search tool for some reason i do not know???
thank you in advance!
ATMINSIDE
If the PDF is searchable, you can use Ctrl+F to find a word.
If it isn't searchable, you'll have to use the old fashioned way... scroll and look.
elfaii
elfaii
i am searching how i can unlock it...
because any of my files has 150 papers at least..
ATMINSIDE
If you can't use the cursor to select the text, you're pretty much out of luck.
elfaii
elfaii
if i can use the cursor but when i copy and paste i take results like that...-> prototype 'ποια θεωρουμε βασικα'
after paste ''Πξια θεωπξύϏε βαςικά'" what i can do???
MattNo5ss
5up3r m0d3r4t0r
If the pdf was created with scanned images, then you need to OCR the document before being able to search it. OCR software isn't always 100% accurate, but it's much better than the scroll-and-look method.
elfaii
elfaii
which ocr i'll try please??
om i finound it i will try it thank you!!
