Seasonic Shows 3,200 W PSU, 16-Pin Connector Cooler, and Advanced Surge Protection at Computex 2025
Kenrou
"At the Computex 2025, Seasonic introduced a range of advanced power solutions for desktop PC performance and reliability. The real standout piece was the PRIME PX-3200, a fully modular 3,200 W power supply compliant with ATX 3.1 standards. This unit delivers 266.7 A on its single +12 V rail and achieves up to 94% efficiency under typical loads, earning 80 Plus Platinum certification, alongside TechPowerUp Best of Computex 2025 award. It can provide its entire power capacity to a single rail, designed for extreme overclocking scenarios. Key features include Micro Tolerance Load Regulation (within 1 %), premium Japanese 105 °C electrolytic capacitors, gold-plated high-current terminals, and a 12-year warranty.
Building on its reputation for thermal innovation, Seasonic unveiled OptiSink 2.0. This next-generation heatsink design improves heat conduction by up to 30 percent through optimized fin spacing and a reconfigured PCB layout accommodating compact MOSFETs. The result is quieter operation and greater long-term reliability. In tandem, OptiGuard adds targeted protection for the graphics card rail, reacting to over-voltage, under-voltage, and spikes within microseconds to preserve GPU health.
Seasonic also teamed up with hardware reviewer King of Wing to launch the 12V-2×6 Ti smart power cable. It offers real-time per-pin voltage and current monitoring, an integrated temperature sensor with an audible buzzer, and the ability to trigger a GPU's own shutdown protection under fault conditions. Builders can further customize this cable with optional heatsinks, fans, and solder configurations, and an external display module keeps vital data in clear view.
In addition to performance and protection, Seasonic emphasized personalization and flexibility. The company's Colorways series features swappable housing panels in multiple finishes, allowing users to coordinate their power supply with any build theme. The CORE Dual power supply offers universal mounting options—horizontal, vertical, or inverted—making it an ideal choice for unconventional or compact chassis designs.
Finally, in collaboration with Noctua, Seasonic unveiled the PRIME HPD PX-1200 Noctua Edition. This 1,200 W unit combines OptiSink enhancements with Noctua's NF-A12x25 G2 PWM fan to deliver whisper-quiet cooling, Micro Tolerance Load Regulation within 0.5 percent, ripple noise below 25 mV, and active power factor correction up to 99 percent. It carries a 12-year warranty and targets silent-PC enthusiasts who demand the very best in performance and acoustics."
Hmm, these 12V power break cables are starting to get a bit dangerous.
I wouldn't use these cables unless the PSU or the OS is aware of the power fault. You can't expect things to be fine if someone just randomly came up and yanked the power cable from your GPU and then left everything else working as is.
PCIe CEM spec is very specific in talking about power down process. The PCIe subsystem must be in reset before the 12V can reach ~10.9V or something like that. If it doesn't there can be sustainable damage to the PCIe device (GPU in this case). I'd only use these things if there was testing proof showing fully loaded GPUs ungracefully being powered down within the spec tolerance.
Not certain why anyone would need a psu that size in any pc to begin with.
Oh me! i need two PRIME PX-3200 too keep my 3v line strong.
Of course im jpking but its clad to see PCP&C of the old days. I know ive even alot of online reviewers sad to see Seasonic
