Hi guys, I'm planning my second build which is going to be a step up from my first as mentioned in the sig. My next system I definitely want to be a dual GPU system but there are a few question I wish to ask.
My situation
18 year old student intending to start university in September.
In need of a system that will take near intense gaming and some audio.
Needs to be one that works well in having an easy future upgrade plan in place.
Be able to last the 3-4 years I'm at university.
Gonna have around £1300 to £2000 from past years savings and working all summer long to spend on this.
AMD or Intel
I would like my CPU to be as high end as possible. So if so, i7 or the A10 to be released .
I am currently swaying towards my next system to be a AMD based system in the benefit of that it is substantially lower in cost and I heard it works better in sync with AMD graphics cards which I favour ultimatly over Nvidia. I do like the look of AMD's trinity and want the A10-5800K, but the reports and articles that suspect AMD have pushed back their piledriver desktop chip releases back to October to shift more Liano chips out of their storage has put me off as I would like this system completed by September. Is it worth the wait for the chip or would you just recommend getting the Intel 3700K (taking in mind it would bite my wallet harder having an Intel based system than a AMD based one.). I've heard that Trinity is reported to perform 40% better in graphics but 20% slower in CPU compared to Ivybridge, is this true?
Motherboard
Would intend entirely on the CPU chosen. Anybody have an idea of if FM2 supports 2 graphics cards and a PCI x1 slot for a sound card?
GPU
At the moment I'm thinking of buying another Sapphire 7770 OC as i have heard that although the card is quite poor on its own it performs significantly higher when in crossfire mode. other ideas i have would be to upgrade to 2x Radeon 78xx series cards or if building an Intel system have Nvidia GTX 550 or 650 ish (my last Nvidia card was a GT 220, I have poor knowledge of the Nvidia Geforce series since it past 9xxx)
RAM
The highest i would wanna go before I think it's ridiculous is 1666MHz. any suggestions?
PSU
650 or 750w be enough for this?
Hard drive
I have got my eyes on a veloceraptor 300GB. but I have been thinking of perhaps a 240GB + 120GB SSD
Case
One requirement of my case is i wish for it to have dust filters so right now it's between the NZXT Tempest 410 elite and the Antec DF-85.
Monitor
No need to worry about this, the only thing not changing at all is that it will remain my current Hanns-G 23"
Any suggestions would be helpful towards this.
thanks
My situation
AMD or Intel
Motherboard
GPU
RAM
PSU
Hard drive
Case
Monitor
thanks
