- Oct 5, 2013
This forum is awesome! You can ask everything you want and you will get proper answer!!! I wanted to sell my PC and buy a new one! I know how much would a modern PC would cost, but mine isn't so modern so I've seen how much my parts would cost but mine are used and that would probably lower it's value!!! Since I've already asked questions in this section and got answers really quickly ans I use an AMD CPU I decided to ask this question in the AMD section!
My specs are:
Motherboard - Foxconn A7VML/A76ML (http://www.foxconnchannel.com/ProductDetail.aspx?T=motherboard&U=en-us0000427)
BIOS version - American Megatrends Inc. version 080014
I'm not sure which CPU do I have because different programs show different model
CPU - AMD Athlon 64 X2 4450e or 4450B Dual-Core or 4450e Dual core but all of them get the same performance and are clocked at 2.3GHz
CPU Cooler - Spire Cooling Fan 12V, 0.20 A
RAM Memory - 2GB Silicon Power DDR2
GPU - GeForce 210 512mb
Optical Drive - Yes
HDD - 500 GB ( Don't know the manufacturer)
Sound Device - Yes
Unknown case model and PSU except i know it's 230 Watts
That's it!
One RAM slot on my motherboard does not work!!!
For how much can I sell it so I can know how much do I have to save to buy the one I like!!!
My specs are:
Optical Drive - Yes
Sound Device - Yes
That's it!
