I noticed from MBM5 that each sensor has a regular setting and a "diode" setting. What is the difference between the two, and how different should the values be?
You can only use the diode setting if you have an Athlon XP and a motherboard that reads from the diode. The "non-diode" setting reads from the in-socket thermisistor. If your board reads from the XP diode, it does not have one of these.
Sorry, I worded it wrong. I meant that if you are using an XP and your board supports the diode then you should set it to read from there. But yeah I know that some boards read both because the Duron and Athlons have temp readings from in-socket.
