Serious Problem... HELP!
TommyDee291
Pennsylvania
Ok, I posted before about trying to overclock my father's aging Emachine PC. Since I know that is near to impossible, I decided just to build him a new one. Not the best but not the worst either. I picked a Intel celeron 1.7 paired with a ASRock M266 Motherboard. After I had the machine built, I started it up, but no video would appear. This has onboard video so thats what i was using. I thought that the bios might have the onboard video disabled... so i tried an agp card.... Not only did that work, but something between the agp slot and the locking bracket got red hot and started to burn and smoke.... So I then tried a PCI video card and still got no luck... Does anyone have any experience with this motherboard? Is this motherboard the cause of the computer problem? Please help!
What AGP card did you try, sounds like you toasted something? Does the manual state which AGP cards the MoBo supports, 2x, 4x , 8x?
Regards, Balrog
The card I chose is not in question. However, it was an old ATI Rage Card.... the card is fine, but the main reason for my post is why I can't get any video to show up... A friend of mine had a similar issue when he was building his and it turned out his motherboard was bad. Is this the same problem?
Well, if something started to get red hot and smoking, that leads me to believe that something's wrong. You gave "burn in" a whole new meaning :~. Balrog is right, what video card did you use? 1x/2x cards are one voltage, 4x cards are a second voltage, and 8x cards are a third. Wrong card in the wrong slot would cause problems, but it seems to me you had a bad board from the get-go.
I know this might annoy you, but are you SURE you did everything right? Sometimes I mess with a pc and I forget to plug something back in and the comp doesn't boot and I get really scared but its no problem, like ram wasn't seated properly. Try resetting the cmos to see if it will start then.
Quailane, I know what you mean. I've built several computers so the chances of me messing up is slim. The one thing I didn't try was reseting the CMOS... On this motherboard it is strange. You have to break the circuit "using a paper clip" it says in the manual. In most boards its just a jumper, so I dunno... I guess I can give that a try.
Well reseting the CMOS didn't work.... So I am going to RMA it back to newegg... As I was inspecting the motherboard, I didn't notice any P4 12v Connector... does a celeron need that 12v connector?
