serious problem with Kt7-Raid need help
SpyderMatrix
VA
ok i have my old KT7-RAID with the kt133 not the kt133a chipset and my configuration is on the
primary raid is a maxtor 15 [email protected] rpm
Secondary none
Primary non raid is 56X CD-Rom ata 66
primary slave none
Secondary Master is Zip 100
secondary slave none
my problem is windows xp will not start up when the zip drive is plugged in but when its not plugged in it starts up fine i have never had this problem before can some one please help??????????
if you need more info i will post it thank you
Sonny
Senior TIFOSI
VARIANTE ASCARI
Operating Systems
It's not really a board problem. You should checkout the OPERATING SYSTEMS section of the forums. I believe they had a few issues similar to yours discussed there in the past.
