Set higher multipliers without hardware mod
flipflop
After read the datasheet of AMD model 8 I didn´t found the pin scheme to set the mulitpliers higher thas 12,5. is it possible to make this modificationa only using the "pin" method, like the vcore method that works very well?
Thanks!
:D
John C.
Thanks! :D
Read the articles at
http://www.beachlink.com/candjac/index.htm
Tbred, Multiplier Code, Workarounds artcles and others are full of logic and Multiplier signal circuits' details...also pinouts.
John C.
