SETI Bench almost 2 hours....ggrrrr....
hipro5
Athens---Hellas
The best I could do is this SETI Bench till NOW.......I had disabled EVERYTHING and I figured out that when I'm bencing with my CPU and my Memory SYNCHRONOUS it's much better to ALL applications and bencmarks.....I've started to believe that if you put the CPU:Mem ratio at 1:1 and with HIGH fsb ,you get better resaults than working the CPU:Mem ratio at 3:4 asynchronous as for Pentium4's.... :(
Mictlan
Senior OC BOINC User
Mexico City, Mexico
So far I have heard it is better to run syncronous as this manages best the memory-chipset-CPU flow.....except that Intel should have had some time to perfect the async interaction now in my opinion.....
They have been using 400-100-200 for sometime so the same algorith that is used for the 4-1-2 impulse could theroretically be improved for the 4-1-1.33, but might be a little more difficult that I think.
Anyway, it was so close 2:01.....can we ask if the 1 minute is complete or just a little less than it :D
hipro5
hipro5
Athens---Hellas
I don't know if the one minute is less than that.....Only Gary Landshark could tell us....
beau_safken
San Francisco CA
Dude Hipro5 You're definetely the man. I know just thru determination you'll get that two minutes...or hopefully three to totally bust the 2 hour mark.
:beer: We're cheering for you!!! :beer:
JigPu
Inactive Pokémon Moderator
Vancouver, WA
There must be something..... Mabey running it on Win98 instead of XP (can't tell if you're using XP or not). That may shave a few more seconds off. Mabey even going Win98Lite to kill off most everything to start off with.
I wanna know how many seconds that WU was.... Just to see how close we are to 2 hours (and any amount of seconds!
JigPu
Yodums
Senior Member
Ottawa, Canada
Stupid question but, have you tweaked XP i.e. disable services, enable registry settings that enhance the memory etc?
That could help a minute or two allow you to break 2 hours.
