(is anyone even reading this? lol)
Yay the 970 arrived! Updated drivers as 312.xx didn't seem to support it, now it's crunching away
It's boosting to 1265mhz straight out of the box, pretty happy about that! Wonder how she will OC?
Ran into some pretty silly problems along the way, though.. So, I have a Silverstone DA850 modular PSU; couldn't find the second dual 6pin cable.. The card came with 2 dual molex->6pin cables, so 4 molex free. Sweet, I find the molex modual, plug it in... only has 3 molex and a FDD connector.. Oh well, I can sort that tomorrow at a PC store, thought I may as well put the cards in anyway, save me having to do it tomorrow.
but no, the 970 doesn't fit in PCI-e slot 1 because of the SATA connectors at the edge of the board (i7 960 on GA-EX58-UD4P). But the 660 Ti's fans touches the exposed RAM chips on the 970.. Now, the UV acrylic case I bought 11 years ago obviously wasn't designed with triple-SLI in mind
neither the 660 Ti nor the 970 will go in slot 3. To further complicate things down the track, I have a PCI-e 1x SoundBlaster Z to wiggle around somewhere.. It won't fit in slot 1 because it hits the mobo's MCH10 HSF, and it won't fit between the 970 and 660 Ti if they're in slot 1 and 2..
Sooo... I pulled the 660 Ti out, 970 in slot 2, SoundBlaster in slot 2. It sucks, but it will have to do for now until I can figure out how best to fix it haha. I *think* my RAC will basically be plateauing at ~17500 anyway I think, roughly given the average daily credit over the 27 days I've been crunching on the 660 Ti, and taking into account the increase I saw when I added CPU crunching, and also OCing the card further... So it will be interesting to see what happens to my RAC at stock boost.. It's 10pm here and as much as I *really* want to stay up and play with this beast, unfortunately..
I've noticed that over the last hour or so I've been crunching, average GPU load is 95%, and while different AR WU will give varying levels of load..HAR/VHAR aka "shorties" are usually quite spiky in GPU load, rarely if ever having long patches of consistent high GPU load sees them constantly bounce between 97-98%, with the occasional 96% and 99% popping up. The yummy long WUs with the 0.38-0.44 AR that are long and give good credit keep the load at 98-99%, with the odd dip to 97%.. But I've never seen this much variation before; I think it's going to trend down soon too as I'm seeing quite a few 93-94%. This is running 2 WU at a time, btw. So obviously I'd be debating doing 3 WU at a time.. I really have no idea; memory controller load is at 80%+ (which is ~11% higher than the 660 Ti), so I'd imagine adding a 3rd in there would just cause congestion and decrease output.. Thoughts? Otherwise I have a good few weeks ahead of me testing things and waiting for RAC to stabilise lol
. The temps at stock boost are staying around 66-67C; which means the fan is on ~11% and I can't hear a thing. Obviously this will all change when I OC it and change the fan profile (I did give 100% a go though
just for funsies~ boy do they motor! lol), but I was still quite impressed with it
hopefully this means there will be quite a bit of headroom for OCing!
Oh, regarding the Xperia Z crunching - I still haven't figured out a way around the battery problem. Using 2 cores and setting it to 1512mhz (max, stock) while wall charging will charge very slowly, but it will charge. I had it plugged in all night last, started with ~34%, ended with ~71%, and all day at work today and it added ~9% or so as it was in very ocassional use. On the plus side, in the almost 3 days since it's been crunching, it's got 522 credit and 47 RAC
go go!
Crunch on!
EDIT: Well, after nearly a month of crunching it looks like the rig is pretty stable at ~35,000 RAC which puts it in the top 125 rigs across SETI... woo! The even better news is that I bought another GTX 970 - this time the Gigabyte Windforce GTX 970 OC.. Will be interesting to see how it compares to the EVGA vanilla ACX2.0 in terms of OCing and RAC. I bought myself a Kill-a-Watt recently and it's been showing ~490W draw 24/7 which is going to be a tad pricey for the power bill, but we'll see. Even though it's still quite a beast, I'm thinking of retiring the 660 Ti as it's literally almost drawing double that of the 970..
660 Ti is rated 150W and GPU-z is showing ~97-103% TDP draw (so let's say 150W average)
970 is rated 145W and GPU-z is showing ~65% TDP draw (~95W average)
Obviously the 970 OC will draw more than this, not the least of which will be due to the *huge* HS and 3 fans... In fact, I'm worried it's not even going to fit! But I'll find a way
Hopefully this will push me into the Top 100 rigs, which would be pretty cool! I'll post some pics of the rig when the card arrives, and I do a bit of cable management and possibly physically modding the mobo (darned 90degree SATA slots in the way)
Crunch on!
