Seti Rank
Vio1
Toronto Canada
Hi, I was wondering if my rank (as specified in Setispy will ever change.. Ive completed 91 hours, 15 returns and since the very first one Im still 2917474 of 4447972 (0.033%)
yes. cant say this point for sure (Pc bust, new rig needs a format so cant cheek if mine changes when i press update.) but... seti have had some problems with the team stats lately maby they also haver problems with the indavidual ones.
thnx
Heres my real stats:
Your rank out of 4473345 total users is: 1556554th place.
The number of users who have this rank: 31979
You have completed more work units than 64.489% of our users
Just keep getting more WU and your rank will improve. As for today
User: Mictlan
Country: Mexico
Results returned: 7019
Total CPU time: 5.04 yrs
Avg. CPU time: 6:17:41
Rank: 17,135 of 4,473,891 (99.617%)
Users with this rank: 3
i feel so ... n00b-ish:
[email protected]
Your credit:
Name (and URL) TriX
Results Received 4
Total CPU Time 30 hr 28 min
Average CPU Time per work unit 7 hr 37 min 09.6 sec
Average results received per day 2.50
Last result returned: Thu May 8 17:09:41 2003 UTC
Registered on: Wed May 7 03:00:57 2003 UTC
SETI@home user for: 38 hr 27 min
Your group info:
You belong to the group named: Overclockers.com Seti Team
You are not currently the founder of any teams.
Your rank: (based on current workunits received)
Your rank out of 4474272 total users is: 2132504th place.
The number of users who have this rank: 109581
You have completed more work units than 49.889% of our users.
Boy it seems like such a long time ago that I had 4 or 15 units. That was back in '99 somwhere whan I was only doing 1 unit in every 28 hrs. You can tell Iv'e improved since than.
Name (and URL) Paradoxmaker
Results Received 9536
Total CPU Time 12.613 years
Average CPU Time per work unit 11 hr 35 min 11.4 sec
Average results received per day 7.61
Last result returned: Thu May 8 17:17:20 2003 UTC
Registered on: Thu Dec 2 05:26:08 1999 UTC
SETI@home user for: 3.434 years
Your rank out of 4474332 total users is: 11010th place.
The number of users who have this rank: 4
You have completed more work units than 99.754% of our users
custom.php
how do you get setidriver to start automatically at windows load up? Is there a way to download a few work units at one time?
This should be enough to answer your question on extra WUs.
To get SetiDriver to load on startup, simply create a shortcut from the setidriver exe, and cut/paste that shortcut into your startup directory.
If you're running Windows XP, it'd be located here..
C:\Documents and Settings\Your User Name\Start Menu\Programs\Startup
The last time I checked, all of this was in the stickies. Is that not the case anymore?
[Edit]...it is.
http://forum.oc-forums.com/vb/showthread.php?s=&threadid=62194
44. : Finally double click the SETI driver icon in your tray, set the desired cache size to 3-5 days worth of work units. If you are not sure how many to set it to set it to 10 and see about how many units you complete in a day and then multiply that by 3 or 5. And also if you have a 24/7 internet connection you can click auto transmit otherwise when you cache gets low you will need to connect to the internet manually and then click the transmit button on SETI driver. You may also wish to connect to one of the teams public queues. Save the configuration and you are now ready to crunch.
Of course, you can make a shortcut to SETISpy and paste it into your system startup folder, then SETI@home will automatically restart, every time you boot up Windows...
Somebody should update the file links to the latest and greatest versions of SETISpy and SETIDriver. The SETI user assignment components are also different in the newer versions of SETISpy, since we no longer need the "workaround".
i use this link for the team
http://www.setiatwork.com/cgi-bin/wkystat.pl?group=Overclockers.com+Seti+Team&name=puffy</a>
my single stats are;..
  • Your credit:
    Name (and URL) MrGuvernment
    Results Received 560
    Total CPU Time 5710 hr 40 min
    Average CPU Time per work unit 10 hr 11 min 51.4 sec
    Average results received per day 4.20
    Last result returned: Mon May 12 16:41:31 2003 UTC
    Registered on: Mon Dec 30 08:32:53 2002 UTC
    View Registration Class
    SETI@home user for: 3200 hr 14 min
    Your group info:
    Your rank out of 4480401 total users is: 269133rd place.
    The number of users who have this rank: 336
    You have completed more work units than 93.986% of our users.
    User Certificates
    Download 500 Workunit Certificate
    Download 250 Workunit Certificate
    Download 100 Workunit Certificate
my average for the seti team is like 10 or 14 per day, which is cloer - cause i started out so slow and not ona team.
