Seti Times on Linux vs Windows
Beelzebub
Irvine, California
Ok, I have a desktop workstation that I dual-boot Mandrake Linux 8.1 and Windows XP and the Seti times are pathetic on the Linux machine.
I have been tracking them with SetiQueue as different clients on one user account, and the Linux OS crunches them in 8:42 while Windows XP does it in 7:48 (yes that is hours). All the hardware is exactly the same since I am only dual-booting. The only difference is the hard drive (same make, just physically different).
I was wondering if anyone out there has noticed the same thing, or are my numbers are just an anomoly. I would prefer to use Linux with the GNOME desktop, but I also want to crunch as many units as possible.
I am using the clc for both OS's, but how can it be that much different?!?! An hour's worth of crunching difference? The AR's on the units have all been pretty close to .400, so it doesn't look like that is the factor. Anyone out there who is experiencing the same thing, lemme know.
Lonely Raven
If you traded with me please leave me Heatware Sen
Wheaton, IL
I was hoping to do the same test, but I've had too many
system boards failing on me lately, and I'm starting in on a
race this Friday.
If I can build a "spare machine", I'll see if I can do the same test.
But I'm a total Linux newb.
LuKE
Enid, Oklahoma
you might wanna double check to see at what "nice" level the client is running under in linux. "Nice" is similiar to priority in windows.
{PMS}fishy
Senior Member
Those times are lame. I would reformat and see if that helps. My celeron does them in 6 hours and the amd in 4 hours. Yours should be doing high 3's I would imagine. SOmething is deff worng. Also linux is slower on any machine, thats just how it is. Oh im running w2k on the amd and xp on the celly.
TC
Senior Seti Addict
Denver, CO
What I've been told is linux is slower with a default installation because it has to be tweaked. People that are somewhat new to linux will likely choose a typical install and you end up with a lot of overhead that you don't necessarily need. BUT - your times are way off to begin with. You may have something else going on. If you can't get it tweaked then you might want to start from scratch.
TC
Senior Seti Addict
Denver, CO
Beelzebub said:
You mean to tell me 7 hours and 48 minutes is a horrible average time for a Pentium III 866?
Oh - no I was looking at the XP 1700+ in your sig...
Team Roper
Mississippi State University
Ok, a tweaked Linux box is slightly faster than a windows box. This is becase the 3.X client was optimized for a windows system.
However, if you know what you are doing in Linux then try this:
Run a Core install on linux, include the kernel source, x-lib, glibc, windowmaker, netscape, and various compilers, & network functions. This will be a quick load, because there is very little installed by the package manager. Next, everything else that you use, download the source code & compile it with your system settings. Try to avoid Gnome (Big Resource Hog) Also, don't load apache, telnet server, or ftp server deamons unless you plan to use them.
Compile your kernel with modular support for everything that you won't use on a daily basis. (ie. USB printers, scanners, etc..) Also, double-check & make sure that you have the correct processors & chipsets listed in your kernel config files before you build the new kernel.
Those steps should cut your WU time down at least by an hour or so. If you have problems running the linux version of the client, try running the windows version in wine... the scary thing is.. I run the seti CLC in wine & it's faster on my system... Go figure!
Hope this helps! :burn: Good Luck! :burn:
Beelzebub
Beelzebub
Irvine, California
Dude! Thanks for the tips! I am gonna try it out and see what I come up with. I will let you know what happens...
I cannot believe that it is faster on you linux box using Wine. That's craaaaazy!
My farm is slowly growing...
AMD 1700+
Intel P3 866
Intel P3 500
soon to be Cely 300A @ 450
Beelzebub
Beelzebub
Irvine, California
I dumped Gnome for Blackbox as my Window Manager and Seti runs sub-4 hour WU's on my XP 1700+ now rather than 4:20+.
The entire system is pretty slim compared to what I was using but I am happy with my Seti times. Now all I have to do is figure out how to compile my own kernel. Thanks Team Roper!
