- Apr 14, 2011
So there is a person i will be setting up security cameras for today. I have had previous exeperience, but this one is different then from what i did before.
Cameras are Lorex LNR6100 will be using POE method to connect to the NVR. NVR will be setup in the laundry room. Cable i will be using is Shireen DC1021.
the under eave is about 10+ feet high from the ground up and another part of the patio is a bit raised so that makes it about 8 feet.
They have no access to an attic at all. No vents or small attic doors. So my questions are
1. Should i just run the cables bare along the back of the under eave and paint the cables to make them blend in? Like the part where it meets the wall of the house. Or should i conceal it with pipe conduit?
2. For now i am running only two cameras so that is two lines through the same hole using a dual wire wall bushing. I would like to be able to run more through the same hole though and i was thinking of using conduit pipe through the brick wall that leads to the laundry room.
Here is a picture to show you where one of the cameras will go. They will also be going to similar spots. I will make sure that the fascia board does not obstruct the top video view of the camera.
EDIT: I forgot to add that the reason why she wanted to get security cameras setup is because there are kids throwing rocks at her house.
