Hi guys, My name is Austin. I'm wanting to build a ITX based to free up room in the living room. The system will be used for emulating everything from the 2600 to game cube games. I'm very out dated on tech and the last time I built anything was back in 2017ish.
So yeah... I need help.
I don't have a budget right now. But I was thinking of the 500$ range for the PC it self. If I need to spend more that is ok.
The requirements are to emulate the falling.
atari 2600, 5200 and 7800.
Sega master system, megadrive, Saturn and Dreamcast.
NES, SNES, n64 and GameCube.
PS1, PS2 would be nice but not needed.
Have alot of usb ports for controllers. I don't want to have to unplug and plug different ones in.
So 8 should do but I can live with 4.
Case must have 1 pci slot opening. I need a older video card like a HD4650 for a TV out as I will use the system on a CRT from time to time and don't want to deal with converters. I don't care if the slot is full size or LP so long as I can fit a single slot GPU in the case with a TV out. I don't care if I have to use a riser cable/card for the GPU ether.
Case must be rather small.
Other then that I don't really care.
I have a m.2 stat SSD in my main PC that I will replace with a NVME SSD so I don't need to buy anything for storage.
Any suggestions?
Any suggestions?
