- Feb 2, 2001
- Roanoke, VA
Has anyone here ever figured out what the story is with wows horrible performance? It seams that almost all systems I've seen it play on, or played it on will perform somewhat acceptable at sometimes but other times it's just horrible. My friend plays wow on an almost identical setup (same Graphics card, same cpu, and even has half the ram I do) but he reports that he gets 40 fps in 25 mans, where as I get 15 ish. I've also played wow on a dell XPS before and it too performed like crap. I just don't get it...it's baffling to me. Even if I turn all the settings to low, textures, anisotropic, view distance, specular lighting, etc. The performance difference is slight in say a 25 man raid. The only setting that makes a big difference on performance is shadow quality (which I keep low, but I shouldn't have to given my system specs)
Here's a bit about my system
OS: Windows xp X64
CPU: Q6600 @ 3 GHz
Bus speed: 333 MHz
Memory: PC2-6400 @ 500 MHz
Graphics card: Nvidia GeForce GTX 260 @ factory clock speeds
As you can see while it's not a 10,000 dollar power house, it should be more than sufficient to run most games at high settings. The only other game I've played on this set up is L4D and it runs fine with all settings and textures high at 1920 x 1080 with a 2x anisotropic filter setting (or 4x? I don't remember). My friend and I even use a custom server so we can spawn zombies, gas cans, propane tanks etc and we go FREAKING NUTS. Fire, and zombies everywhere, explosions everywhere, and I don't see so much as a hiccup. It's beyond me :\ maybe it has something to do with the fact that he's on vista and I'm on x64? Maybe windows 7 would run it better Any ideas?
OS: Windows xp X64
CPU: Q6600 @ 3 GHz
Bus speed: 333 MHz
